1. Re: Print form data
George Johnson Nov 10, 2014 10:24 PM (in response to NViereckel)What sort of fix do you imagine would be ideal?
You can set a field's font size to Auto, which will case the it to auto-reduce in the attempt to display all of the text in a field, down to a minimum of 4 points.
2. Re: Print form data
NViereckel Nov 11, 2014 1:26 PM (in response to George Johnson)Hi George - well ideal would be to see the text that has been inputted into the boxes. The data is there, but because there are more lines that can be displayed in the box size, e.g. 5 lines of text, but only 3 display. Only the 3 lines (what you see) gets printed. Like the way you can print out comments. Same kind of concept.
And alas having text printed at 4pt is not a very useful option as it gets too hard to read.
Thanks for your thoughts though. Something to consider next time a client asked for a fillable pdf. I will need to let them know they need to limit the text they want to allow to be inputted. Or use another program.
Cheers
N
