1. Re: How was this done (Stacking)?
hans-g. Nov 10, 2014 11:17 PM (in response to Picturequest)Hi Alex,
this tool is usually called the Blur or soft-focus effect (translated from my German PS). Many programs offer this brush for applying to the effect. Often you can select the photo, create a soft edge selection and then make the selection using filter blurred or you yourself blur some of the image areas.
And we have the tool "Unsharp Mask". For this purpose, only the original image and a blurred version are required. The layer structure, however, shows good results only if your program supports 32-bit color depth, like Photoshop.On the other hand, I'm sure you will get better explanations, by asking Riccardo Magherini himself at http://www.riccardomagherini.com/fine_art/contact/. I'm sure you will get answers marked of a professional competence and responsibility.
Hans-Günter
2. Re: How was this done (Stacking)?
Picturequest Nov 11, 2014 8:52 AM (in response to hans-g.)Thank you. But I'm pretty sure this is a STACK of multiple exposures. I don't see any blur.
3. Re: How was this done (Stacking)?
rkelly0137 Nov 11, 2014 9:12 AM (in response to Picturequest)I'm not sure I'm looking at the right image... are you talking about the one of Time Square in the background? I agree, I wouldn't use unsharp mask for that. "Stacking" actually has a different meaning when it comes to Photoshop/digital manipulation, but I think your assumption is correct that it's just a bunch of layers stacked on top of each other, with various transparencies. What makes it different from most times you see this effect, is that he didn't keep the background static either. Usually you put your camera on a tripod, take a bunch of shots, then load them into layers and adjust the transparency and/or mask to get the effect you want. This one you can see he moved images around wherever he wanted (for example, the Disney sign in the middle isn't really there).
4. Re: How was this done (Stacking)?
Dsarchy Nov 11, 2014 9:16 AM (in response to Picturequest)I would argue two things:
a) that you would save yourself some time by not posting a question that you obviously know the answer to.
b) that hans-g is correct, I can't see one hard edge in the picture.
5. Re: How was this done (Stacking)?
If point b) is correct, then he didn't know the answer to it, which is why he asked in the first place. The very fact that there is a conversation as to what effects he used demonstrates that it's the very kind of thing that you discuss in a chat forum, to see what different opinions are.
It's hard to tell what is sharp and what's not, given the layout and transparencies. The person dressed as a statue of liberty looks relatively sharp to me. It also gives no indication as to what the photographer was focusing on, so it's hard to say if the background fuzziness is due to filters, or simply depth of field. Regardless, I wouldn't use an unsharp mask for that effect. Which, again, is why we have this post. There are many ways to do things in Photoshop.
6. Re: How was this done (Stacking)?
hans-g. Nov 11, 2014 9:54 AM (in response to rkelly0137)Hello Alex, hello Dsarchy and rkelly0137,
as already stated, it's certainly not so easy and it takes a lot of experience to get a satisfactory result. So in my eyes, the best would be as I wrote above: "On the other hand, I'm sure you will get better explanations, by asking Riccardo Magherini himself at http://www.riccardomagherini.com/fine_art/contact/. I'm sure you will get answers marked of a professional competence and responsibility." Despite the fact that it would cause costs for you Alex, it might be worth.
I eagerly await the next steps.
Hans-Günter
7. Re: How was this done (Stacking)?
Picturequest Nov 11, 2014 11:18 PM (in response to hans-g.)These forums have gotten weird. Too adversarial. I know what stacking is, but never used it. Plus the images are like in the old day of multiple exposures on a single frame of film.
I asked the question to start a discussion and hopefully get some advice from others in the forum who may have had experience.
I really don't see where bluing or unsharp mask would be used here at all?
As for asking the photographer his secrets on how he does his technique, that often does not receive a response.
