1. Re: Acrobat version 8 to 11
Gilad D (try67) Nov 11, 2014 7:48 AM (in response to lenfrombako)If the forms were created in Acrobat then you can edit them in Acrobat. If
they were created in LCD then you have to use LCD to edit them. And
starting with Acrobat XI LCD is no longer bundled with it for free. You
need to purchase it separately.
On Tue, Nov 11, 2014 at 4:47 PM, lenfrombako <forums_noreply@adobe.com>
2. Re: Acrobat version 8 to 11
lenfrombako Nov 11, 2014 8:35 AM (in response to Gilad D (try67))Thank you for your answer. I just opened Acrobat Pro 8 and created fill forms. It said nothing about it using LCD. Can I use version 8 to convert all these forms in an acrobat form that I can edit in version 11?
3. Re: Acrobat version 8 to 11
Gilad D (try67) Nov 11, 2014 8:38 AM (in response to lenfrombako)You can't convert LCD forms to Acrobat forms directly, in any version of
Acrobat. The only way to do it is to print the file to the PDF printer,
creating a static copy of it, and then add the fields to this new PDF in
Acrobat from scratch.
On Tue, Nov 11, 2014 at 5:35 PM, lenfrombako <forums_noreply@adobe.com>
4. Re: Acrobat version 8 to 11
jnicholas330 Nov 11, 2014 6:07 PM (in response to lenfrombako)You may be eligible for a free upgrade to LiveCycle Designer ES4. See the following link: Upgrade Adobe Designer | Acrobat XI
