1 Reply Latest reply on Nov 11, 2014 9:47 AM by a_lez
    ADE doesn't start on windows 7
    a_lez
      After the installation of ADE without error, I'm able to start ADE. But after restart of my PC I'm not able to start ADE. ADE doesn't start and no error messages appears.
      I can see ADE started in the "Windows task manager" but after few second it dissapears.
      I tried to de-install and re-install ADE with no more success.
      Thank you for your help and support.
      Regards
      A_lez
        • 1. Re: ADE doesn't start on windows 7
          a_lez Level 1
          I have check the windows event log. And the following message appears:
          - <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
          - <System>
          <Provider Name=".NET Runtime" />
          <EventID Qualifiers="0">1026</EventID>
          <Level>2</Level>
          <Task>0</Task>
          <Keywords>0x80000000000000</Keywords>
          <TimeCreated SystemTime="2014-11-11T17:25:34.000000000Z" />
          <EventRecordID>83917</EventRecordID>
          <Channel>Application</Channel>
          <Computer>AudBen-PC</Computer>
          <Security />
          </System>
          - <EventData>
          <Data>Application : DigitalEditions.exe Version du Framework : v4.0.30319 Description : le processus a été arrêté en raison d'une exception non gérée. Informations sur l'exception : System.Configuration.ConfigurationErrorsException Pile : à System.Configuration.BaseConfigurationRecord.GetSectionRecursive(System.String, Boolean, Boolean, Boolean, Boolean, System.Object ByRef, System.Object ByRef) à System.Configuration.BaseConfigurationRecord.GetSection(System.String) à System.Configuration.ClientConfigurationSystem.System.Configuration.Internal.IInternalCon figSystem.GetSection(System.String) à System.Configuration.ConfigurationManager.GetSection(System.String) à System.Configuration.ClientSettingsStore.ReadSettings(System.String, Boolean) à System.Configuration.LocalFileSettingsProvider.GetPropertyValues(System.Configuration.Set tingsContext, System.Configuration.SettingsPropertyCollection) à System.Configuration.SettingsBase.GetPropertiesFromProvider(System.Configuration.Settings Provider) à System.Configuration.SettingsBase.GetPropertyValueByName(System.String) à System.Configuration.SettingsBase.get_Item(System.String) à System.Configuration.ApplicationSettingsBase.GetPropertyValue(System.String) à System.Configuration.ApplicationSettingsBase.get_Item(System.String) à DE.ConfigurableWindowSettings.GetValue[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]](System.String) à DE.ConfigurableWindowSettings.get_LibraryContentView() à DE.MainWindow..ctor() à DE.App.OnStartup(System.Windows.StartupEventArgs) à System.Windows.Application.<.ctor>b__1(System.Object) à System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate, System.Object, Int32) à MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(System.Object, System.Delegate, System.Object, Int32, System.Delegate) à System.Windows.Threading.DispatcherOperation.InvokeImpl() à System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(System.Object) à System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) à System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) à System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object) à System.Windows.Threading.DispatcherOperation.Invoke() à System.Windows.Threading.Dispatcher.ProcessQueue() à System.Windows.Threading.Dispatcher.WndProcHook(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef) à MS.Win32.HwndWrapper.WndProc(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef) à MS.Win32.HwndSubclass.DispatcherCallbackOperation(System.Object) à System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate, System.Object, Int32) à MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(System.Object, System.Delegate, System.Object, Int32, System.Delegate) à System.Windows.Threading.Dispatcher.LegacyInvokeImpl(System.Windows.Threading.DispatcherP riority, System.TimeSpan, System.Delegate, System.Object, Int32) à MS.Win32.HwndSubclass.SubclassWndProc(IntPtr, Int32, IntPtr, IntPtr) à MS.Win32.UnsafeNativeMethods.DispatchMessage(System.Windows.Interop.MSG ByRef) à System.Windows.Threading.Dispatcher.PushFrameImpl(System.Windows.Threading.DispatcherFram e) à System.Windows.Threading.Dispatcher.PushFrame(System.Windows.Threading.DispatcherFrame) à System.Windows.Threading.Dispatcher.Run() à System.Windows.Application.RunDispatcher(System.Object) à System.Windows.Application.RunInternal(System.Windows.Window) à System.Windows.Application.Run(System.Windows.Window) à DE.App.Main()</Data>
          </EventData>
          </Event>
          And I'm not able to understand the real reason.
          If someone can understand this message it will be helpful.
          Regards,
