2 Replies Latest reply: Nov 11, 2014 1:31 PM by darren beason RSS
    Is there an action script to automate a number sequence on top of a static graphic?
    darren beason
      I have a ongoing task to output map marker (pins), 1-99 versions, for a Bing map. Problem is we can't code the text so we have to create 1-99 map marker image files. Since I am bound by the constraints of this, does anyone know a way to automate this process in Photoshop using Action Scripts or something else. Right now, I've set-up individual layers with each number on a layer, and then a blank map marker on a layer. Then I use Layer Comps to export it using Scripts/Layer Comps to files.
      Thanks for the help, if someone can figure this out.
