1. Re: Connect my CASIO CTK-4200 to Audition
SteveG(AudioMasters) Nov 11, 2014 1:46 PM (in response to sebwa23)Sorry to disappoint you, but...
I suspect that the reason you found the keyboard under the controller surface settings is that it uses the same interface - but I'm afraid that's about as far as it goes. Audition doesn't support MIDI, which is the protocol you would need to be able to record the keyboard. Also, as a consequence it has no sounds available. This is fundamentally because Audition is an editor, not music creation software. This has been discussed at length here before, but nothing about this situation is likely to change. It's not an area in which Adobe has any significant experience at all, and they'd spend forever playing catch-up with the rest of the software that's done this for ages. The only way you could record the output of your Casio would be as audio from the device itself, which is clearly not what you're trying to do.
If you want to achieve the results you are looking for, you'd be much better served by using proper music creation software like Reaper, which is designed to do exactly what you want - although as an editor, it leaves a lot to be desired.
