0 Replies Latest reply: Nov 11, 2014 1:28 PM by Deel1 RSS
    RH11 showing FM paragraph formats in linked DITA topics
    Deel1 Community Member
      Hi all,
      I'm using TCS 5 on Windows 8.1, and I recently upgraded to the latest Framemaker (12.0.3) and RoboHelp (11.0.3) releases through Adobe's auto-updater.
      I have an RH help project that is linked (not imported) to an FM DITA map. I use this setup to generate Responsive HTML5 output from my DITA topics, which I edit in FM. I'm fairly new to structured workflows, so I'm hoping some of the experts here can help me.
      Since installing the latest FM and RH application updates, I have a problem where formats from the FM structured template are showing up in the RH topics, even though I've mapped the FM formats to RH styles in Project Settings. Here's an example DITA task:
      The "Task" line above the first step is from the FM template, which dictates that the step.begin paragraph format should have the StepsBegin frame above it. But I changed the style mapping in RH so that the step.begin format maps to an RH style (BodyLevel1). So I don't understand why this "Task" line is showing up; in fact, it didn't show up before I installed the latest application updates.
      As an attempted workaround, I edited the step.begin format in the relevant FM structured template so that there is no frame above it. I was successful in that the Task line no longer shows up when I edit DITA tasks in FM. But for some reason, it still shows up in RH!
      I uninstalled TCS 5 and reinstalled to see if the problem went away, and sure enough, everything was fine. But when I reapplied the FM and RH application updates, the problem returned.
      I'm at my wits' end on this one. Any suggestions out there? Does this seem like a bug?
