1 Reply Latest reply on Nov 12, 2014 4:07 PM by Sean_Wilson
    newproxycallback question
    bluelemonade Level 1
      hello
      inside a flash sprite behaviour I initialize my callback
      on beginssprite me
      pCB = sprite(me.spriteNum).newProxyCallback(#sendToLingo)
      sprite(me.spriteNum).stage.getChildAt(0).addEventListener("sendToLingo", pCB)
      end
      -- this function is called from the flash.
      on sendToLingo me, evt
           put "Data received from AS3:" && evt.data
      end
      inside flash I have a class to get some values via tcpip, this works fine...
      I add an ondataArravied eventlistener to rhis object.
      com_pci.addEventListener("dataArrived",onDataArrived);
      that calls the method
      function onDataArrived(e:Event){
      trace("onDataArrived " + getTimer() );
      comInAry = com_pci.data;
      var tempPos:String = (comInAry[0]).toString();
      if (tempPos != currSlidePos) {
          trace("onDataArrived and changed" + getTimer() );
          dispatchEvent( new LingoEvent("slidePos:" + currSlidePos) );
      OK, when I onDataarrived is called one, I get a bunch of events in director, every time the tempPos != currSlidePos I get 20 or 30 times the sendToLingo
      event in director. why, the trace inside flash is only fired once...
      would be nice to get some help.
      regards.
        • 1. Re: newproxycallback question
          Sean_Wilson Adobe Community Professional
          You should wait until your flash sprite has initialised before setting up communications. Something like the following typed as a #parent script and named "init" in your castLib:
          -- parent script "init"
          on enterFrame me
            sendSprite(me.spriteNum, #init)
          end
          and attached to the Flash sprite:
          property spriteNum
          property my
          property ancestor
          on beginSprite me
            my = sprite(spriteNum)
            ancestor = script("init").new()
          end
          on init me
            ancestor = VOID
            cb = my.newProxyCallback(#sendToLingo)
            my.stage.getChildAt(0).addEventListener("sendToLingo", cb)
          end
          -- etc.
          This will force the Flash sprite to wait for one frame cycle before setting up.
