1. Re: cannot log in with Adobe I.D.
timmyleeturner Nov 11, 2014 4:28 PM (in response to timmyleeturner)I should have added, I can only close the program with Ctrl Alt Del and shut it down while this is happening... cannot close the window.
2. Re: cannot log in with Adobe I.D.
Barbara B. Nov 11, 2014 5:52 PM (in response to timmyleeturner)You can't log in in PSE 10 because there is nothing at all to log in to anymore. Photoshop.com has been dead and gone for over a year now, and that was what the login was for. Just skip it.
3. Re: cannot log in with Adobe I.D.
andaleebfatima1 Nov 11, 2014 10:47 PM (in response to timmyleeturner)Please rename opm.db file located at-
Win:C:\Users\AppData\Local\Adobe\OOBE
Mac:Users Library/Application Support/Adobe/OOBEand try to sign in again.
If this does not work, please Navigate to below location
C:\Program Files (x86)\Common Files\Adobe
and rename the SLCache folder to SLCache.old
and launch Photoshop Elements from there and check.
Andaleeb
4. Re: cannot log in with Adobe I.D.
timmyleeturner Nov 12, 2014 3:42 AM (in response to Barbara B.)You should be able to log into your Adobe account using your I.D. I can do it with Elements 12. I can do it at Adobe Web Site, but NOT from within the program as intended. What do you mean there is nothing there? A list of all my purchases, serial numbers etc are there.
5. Re: cannot log in with Adobe I.D.
timmyleeturner Nov 12, 2014 4:10 AM (in response to andaleebfatima1)I tried both of the above suggestions, renamed opm.db file to old and could not locate a SLCache folder in (x86)/Common Files... so I looked in Program Files/Common Files and not there either.
6. Re: cannot log in with Adobe I.D.
dsumner Nov 12, 2014 4:30 AM (in response to andaleebfatima1)I am having the same issue, Photoshop elements stopped working no my Windows PC after it downloaded the 8.1 update. I cant open it at all.wn+
I have since downloaded elements 12 on another PC (Windows XP) but it asks for my ID and password, when I put that it the programme does nothing. I dont understand your message about changing OBE or Cache file, can you put step by step instructions on please Andaleeb ?
Many thanks in advance
7. Re: cannot log in with Adobe I.D.
Barbara B. Nov 12, 2014 5:46 AM (in response to timmyleeturner)Elements 12 is COMPLETELY different in this regard from PSE 10.
8. Re: cannot log in with Adobe I.D.
Barbara B. Nov 12, 2014 5:46 AM (in response to timmyleeturner)PSE 10 is not like PSE 12 and 13! You don't have to sign in to use the program.
9. Re: cannot log in with Adobe I.D.
timmyleeturner Nov 12, 2014 7:40 AM (in response to Barbara B.)Ok, thanks. Seems odd that you have the Log In button there and when you click it, it locks up your program and you have to force it closed. I guess just knowing it's useless helps.
