1. Re: Alt key shortcut woes in InDesign CS6
Peter Spier Nov 12, 2014 2:51 AM (in response to Kevin Stauffer)I don't believe this is a general Windows problem (which version of ID and of Windows are you running?), but is more likely a configuration issue of some sort on your systems. Do you use any third party plugins?
2. Re: Alt key shortcut woes in InDesign CS6
Kevin Stauffer Nov 12, 2014 10:23 AM (in response to Peter Spier)Peter,
We are running Windows 8.1 and have also done testing on a Windows 7 machine, all running InDesign CS6. The common plug-in is for auto font activation via Universal Type Server. I think that Windows does use the Alt key to shift focus to the menu of whatever app you are in, but I certainly could be mistaken. Just really in need of a solution
Kevin
3. Re: Alt key shortcut woes in InDesign CS6
Peter Spier Nov 12, 2014 4:00 PM (in response to Kevin Stauffer)Disable the UTC plugin and I think you'll find the Alt key works again...
4. Re: Alt key shortcut woes in InDesign CS6
Kevin Stauffer Nov 12, 2014 4:56 PM (in response to Peter Spier)Peter,
I disabled the UTC plugin. No change; shortcuts with the Alt + Num key do not work on the PC
5. Re: Alt key shortcut woes in InDesign CS6
Peter Spier Nov 13, 2014 2:42 AM (in response to Kevin Stauffer)I've never developed a desire to use style shortcuts in my work, but I just checked, and it doesn't work here, either, so it looks like you are correct, which is obviously a big problem. Doesn't work in CC 2014, either, or in CS3 which is the oldest version I have installed on this laptop, so I suspect it's an OS limitation of some sort.
6. Re: Alt key shortcut woes in InDesign CS6
Bob Levine Nov 13, 2014 4:25 AM (in response to Peter Spier)I seem to remember a discussion about this a while ago. I’ll see what I
can dig up about it.
7. Re: Alt key shortcut woes in InDesign CS6
Bob Levine Nov 13, 2014 4:36 AM (in response to Peter Spier)I remember now…the alt key is used to activate menu commands to be used by
keyboard instead of mouse in Windows. This is a great feature but in this
case does conflict with InDesign keyboard shortcuts.
There may be some workarounds but you’re probably better off using
different shortcuts for those styles.
8. Re: Alt key shortcut woes in InDesign CS6
Bob Levine Nov 13, 2014 5:03 AM (in response to Kevin Stauffer)Here’s an article that explains the alt key shortcut issue on Windows: http://indesignsecrets.com/applying-alt-w-for-preview-in-windows.php
