2 Replies Latest reply: Nov 12, 2014 10:03 PM by ShaG1 RSS
    Adobe CC 2014 - Crash with Comps with Particular in them
    ShaG1 Community Member
      I've noticed a problem when having particular inside a comp.
      In previous version of AE I can have particular inside a comp and then add any of the following to the comp - Hold Frame or Time Remap - so I can loop the comp etc.
      Now in AE CC 2014 this is causing a crash as soon as you add any time related effect.
      Does anybody know if this is on the radar to be fixed? Or is there a workaround other than duplicating the layer multiple times.
      Edit: Forgot my Specs:
      AE CC 13.1.1.3
      Windows 7 Enterprise
      Intel Core i7-3930K CPU @ 3.20GHz
      32GB RAM
      NVidia GeForce GTX 670
      Thanks for the help.
      ~Shaul
        • 1. Re: Adobe CC 2014 - Crash with Comps with Particular in them
          Rick Gerard CommunityMVP
          If you are applying the time effects to a nested comp that contains Particular run a quick test by creating a new composition, adding particular with the default settings, pre-compose the particular layer and then add your time effects. If that works then check you settings in Particular and the other layers in the nested comp. If the simple test crashes then let us know. It works fine on my system. If you apply any time effects that can be applied to a layer that has particular or any other particle generator applied you will either have a lock up or crash. You MUST pre-compose time based effects like particle generators before applying time effects like Frame Hold or Time Remap. Most of the time AE will not even let you apply these effects.
          • 2. Re: Adobe CC 2014 - Crash with Comps with Particular in them
            Hi Rick,
            Thanks, I did as you asked - just added particular with it's default setting, pre-composed and added Time Remap.
            That seems to work fine as well, but as soon as I do either of the following scenarios it crashes:
            Scenario 1:
            -Have Partcular Precomp shorter than Main comp  (My Instance - Particular Comp 5 Seconds, Main Comp 10 Seconds)
            -Add Time Remap to Particular Comp
            -add a keyframe 1 frame before the end of the Precomp.
            -Delete the last keyframe (So particles don't disappear
            -Extend the comp to the end
            -(I would usually use a Loop expression at this stage - but AE crashes)
            Scenario 2:
            -Have Particular Precomp in a Main Comp
            -Move to the middle of the Precomp
            -Add a Hold Keyframe
            -This ends in a crash
            Let me know if this is fine on your side.
            Thanks for the help
            ~Shaul
