Hi Everyone
Is there a photo slideshow plugin that you can use in the fluid grip layout with a fluid div? I tried using cycle2. But i cant get it to work. the plugin requires the div tag to be called cycle-slideshow but when I insert a new div it won't allow me to type in cycle-slideshow. When I try code the div I can't seem to get a fluid element. Is there a way around this problem?
all good I was able to fix the problem by amending the script code
