1. Re: Create and save a multipdf as folder name?
Gilad D (try67) Nov 12, 2014 1:21 AM (in response to kent2014)What kind of "macro"?
2. Re: Create and save a multipdf as folder name?
kent2014 Nov 12, 2014 1:42 AM (in response to kent2014)I used the built in tools in Acrobat XI Pro.
3. Re: Create and save a multipdf as folder name?
Gilad D (try67) Nov 12, 2014 1:44 AM (in response to kent2014)A script? An action? If you want help please elaborate a bit.
4. Re: Create and save a multipdf as folder name?
kent2014 Nov 12, 2014 1:55 AM (in response to Gilad D (try67))Hi.
Sorry if I express myself bad. I use the swedish version so it might be a little incorrect translation. This is how I did. Tool/.../create new action. I choosed "combine files". When this action is done I must save the "Binder" file manually. I want it to be saved as the folder name in which the files are. Then it continues with OCR and finally the pdf file is saved as PDF/A. OCR and PDF/A is done autimaticly when I have saved the file. Understandable?
5. Re: Create and save a multipdf as folder name?
Gilad D (try67) Nov 12, 2014 2:01 AM (in response to kent2014)OK, now I understand. It's not possible to automatically save the file under a specific name when doing it like that because you have no access to the paths of the files that are being combined. Also, in principle these files don't have to be all located under the same folder, so it would be technically impossible to do it anyway.
I have developed a combination of a script and an Action that does allow you to do it, but in your case it would involve many more steps than simply entering the name manually, I think. -
6. Re: Create and save a multipdf as folder name?
kent2014 Nov 12, 2014 2:06 AM (in response to Gilad D (try67))It seems I will have to continue saving the file manually since I do not know how to do that script
