5 Replies Latest reply on Nov 12, 2014 11:14 AM by 20pictures
    Full-size Image Export bug
    20pictures
      I am trying to export an image from Lightroom as a full-size JPEG (quality 100%). 'Limit File Size' is unchecked as is 'Resize to Fit'. Lightroom Version 5.6.
      The original image is 3000px square & yet the exported JPEG is 1000px square! I was exporting a virtual image so I tried the original RAW file with the same result. I tried exporting different file types but always the same outcome.
      The only way I could get a full-size image ready for my client was to check 'Resize to Fit' & enter the original file size dimensions. I hope this does not affect the resultant quality?
      Clearly, there is an unacceptable export bug. On this occasion I only had to export one image but I need to export in quantity (& varying original sizes).
      Any advice?
        • 1. Re: Full-size Image Export bug
          20pictures Level 1
          I have found a workaround fix for this issue. Opening the Lightroom Default 'Burn Full-Size JPEGs' preset, I have made changes to the destination & metadata requirements. It now exports correctly.
          This still does not explain why a custom preset is not accepting my input parameters. Yes, I did reboot Lightroom!
          • 2. Re: Full-size Image Export bug
            DdeGannes Adobe Community Professional
            Just a thought. Any crop applied to the original image in Lightroom?
            • 3. Re: Full-size Image Export bug
              20pictures Level 1
              Yes, it was cropped square. However, exporting the original uncropped file still had the resize bug. It seems Lightroom has cached a previous export setting & will not clear the cache when resize is unchecked (even after reboot). The success of using the original default preset would support this theory.
              • 4. Re: Full-size Image Export bug
                NicHamilton Level 3
                Not something I can reproduce, assuming I'm understanding the issue and I may not be.  A few more questions....
                What's your OS?
                Can we have all of the settings for the Custom Pre-set to try and reproduce it please?
                Also, you've said it's not an issue if you modify the built in "Burn full size jpgs" pre-set. What about if you save this modified pre-set as a new pre-set?
                Again, what about rebuilding a custom pre-set from scratch, is it still an issue?
                Thanks.
                • 5. Re: Full-size Image Export bug
                  20pictures Level 1
                  I used the modified default 'Burn Full-Size JPEGs' preset & saved it, overwriting the faulty one in the process! Using Windows 7 64-bit.
                  Will try making some new presets & see if I get the same issue. Anyone know if there is a cache that can be cleared in this situation?
                  Settings -
                  Export to: Hard Drive
                  Export Location -
                  Export to: Specific Folder
                  Folder: xxxx
                  Put in Subfolder: zzzz
                  File Settings -
                  Image Format: JPEG
                  Quality: 100
                  Color Space: AdobeRGB
                  Limit File Size: unchecked
                  Image Sizing -
                  Resize to fit: unchecked
                  Resolution: 300ppi
                  Metadata -
                  Include: All except camera & camera Raw info
                  Remove Location Info: checked
