4 Replies Latest reply on Nov 13, 2014 11:42 PM by BEGINNER_X
    Sharing Knowledge
    BEGINNER_X Level 3
      Hi All,
      Use below function for avoid Unique or duplicate in arrays:
      myTextFile2.write( "Ligatures Missing\t" + unique(myParaPageArray) + "\n")
      function unique(myPs) {
          var newArray = new Array();
          label: for (var i = 0; i < myPs.length; i++) {
              for (var j = 0; j < newArray.length; j++) {
                  if (newArray[j] == myPs[i]) continue label;
              newArray[newArray.length] = myPs[i];
          return newArray;
      Please share this kind of functions. Surely helpful for lot of programmers.
      Regards
      Siraj
        • 1. Re: Sharing Knowledge
          Loic.Aigon Adobe Community Professional
          Hi Siraj,
          I guess the most valuable place for sharing such snippets is GitHub. I have dropped an eye and there are already various js array libraries. If not, you can start creating one and have fellows enriching it
          Loic
          • 2. Re: Re: Sharing Knowledge
            BEGINNER_X Level 3
            Hi Loic,
            Thanks for your knowledge...
            I learn how to use "GitHub" and get back to you...
            Any other function is appreciable....
            thanks Chinna,
            Another Function:
            Array.prototype.contains = function(k)
              for(var i=0; i < this.length; i++)
                    if(this[i] === k)
                        return true;
              return false;
            var _layers = [ "BaseArtwork", "MagentaVariables", "PreprintedText", "OtherVariables"];
            var match = [];
            var ly = app.activeDocument.layers.everyItem().getElements();
            if(ly.length == 4){
                for (i=0; i<ly.length; i++)
                    if (_layers.contains(ly[i].name))
                            match.push(i);
            • 3. Re: Re: Sharing Knowledge
              Sajeev Sridharan Level 4
              Nice Sharing...
              Another method:
              var myTestArray = [10, 10, 12, 12, 14, 15];
              alert( "Unique Array List\t" + unique(myTestArray));
              function unique(myArray)
                  var test=[];
                  var newArray = [];
                  for (i=0;i<myArray.length;i++)
                      test[myArray[i]]=0;
                 for (i in test)
                      newArray.push(i);
                  return newArray;
              Vandy
              • 4. Re: Re: Re: Sharing Knowledge
                BEGINNER_X Level 3
                Hi All,
                My plan is gather this kind of functions and how to use it like for beginner and junior developer.
                Already Mentioned function but with different examples...
                Thanks csm_phil, this is your coding
                var myFile = File.openDialog("Choose a tab delimitted txt file:");
                if (!myFile){
                exit();
                var myArray = []
                myFile.open('r');
                while (myFile.eof==false){
                    var line=myFile.readln().split(",");
                    myArray.push(line[0]);
                var myPstyles = app.activeDocument.allParagraphStyles;
                Array.prototype.contains = function(obj) {
                    var i = this.length;
                    while (i--) {
                        if (this[i] === obj) {
                            return true;
                    return false;
                var myMissingStyle =[];
                for(i=2; i<myPstyles.length; i++){
                    var myS =myPstyles[i].name;
                    if(myArray.contains(myS) !=true){
                        myMissingStyle.push(myS);
                //I showed only missing styles names, If you want a report file, please you have generate it.
                alert(myMissingStyle.join("\n"));
                Regards
                Siraj
