4 Replies Latest reply on Mar 18, 2007 8:38 PM by kglad
    Random Shuffe Array
      Hello Action Script Writers,
      I am new to action script although understand the basic programming principals
      and have worked from template scripts in the past.
      I would like to place a piece of script within 1 cell which will then
      request 1 of 5 files on a random basis (named 1.swf - 5.swf)
      if you can help an explanation of your code would also be appreciated.
      thank you
        • 1. Random Shuffe Array
          This should work. Check the Flash help for description of the loader, Math.random() etc.
          • 2. Re: Random Shuffe Array
            the shuffle() method for arrays is to be used when you don't want repeats. otherwise, the simple code given by eric is sufficient.
            • 3. Random Shuffe Array
              Script_Newbie Level 1
              thats great thanks, i'll experiment with it
              i need to be more particular about the array qualities as
              i intend to use the final code 6 times with variations
              across 6 TV channels / Cells.
              In other words, in
              cell 1 = movie channel
              play random but dont repeat 1.swf - 99.swf
              cell 2 = sports channel
              play random but dont repeat 100.swf - 199.swf
              i already have a radomiser to land on any one of the 6 channels.
              The objective is that with these 6 new shuffle arrays
              (each shuffle array defining the .swf parameters for that channel...
              ie 1.swf - 99.swf)
              are combined with the existing channel randomiser viewers will be
              able to land randomly across 600 shows.
              you can see a working example of the channel randomiser at www.bulletprooftv.com
              • 4. Re: Random Shuffe Array
                check this forum for the array.shuffle() method if you need it.
