1 Reply Latest reply on Mar 25, 2007 6:09 AM by Chunick
    Field's scrollbars aren't working with long lists
    kmdguy
      Hi there, I have a field castmember which displays long lists of URLs.
      The height of the field is 145.
      When the list has LESS than 4,690 lines in it, the scrollbar slider works fine if you drag it all the way to the bottom. You get the very last line in the list as you would expect.
      However, if the list exceeds this number, then the scrollbar slider doesn't reveal the bottom of the list. If you drag it all the way down to the bottom, it only displays up to 4,691 lines. If you want to see more then you must click and hold the down arrow, but that method is very slow.
      Is this a limitation of the field type castmember or is there a workaround?
