7 Replies Latest reply on Nov 14, 2014 5:57 AM by A.T. Romano
    Menu Markers
    Michael Stehly Level 1
      I have several sports video clips.  I am using one of the Menus.  No matter which one of the Menu Markers I use, when the first video plays, it will not go back to the Main Menu.
        • 1. Re: Menu Markers
          A.T. Romano Level 7
          Michael Stehly
          Please describe your situation in this instance....
          a. What is involved - DVD-VIDEO on DVD disc, AVCHD on DVD disc, or Blu-ray disc format on Blu-ray disc?
          b. Have you placed stop markers on the Timeline at the end of each video except the last one?
          c. Are you using a main menu page and scene menu page setup or just a main menu page setup for the project?
          Which specific theme are you using although I do not believe the theme itself is the issue?
          Thank you.
          ATR
          • 2. Re: Menu Markers
            I am using the Main Menu Page and the Scene Menu Page Setup.  When I place the Stop Markers, each scene menu is deleted.
            • 3. Re: Menu Markers
              A.T. Romano Level 7
              Michael Stehly
              Please remind me
              AVCHD format on DVD disc
              Blu-ray disc format on DVD disc
              It is going to matter. Stop markers do not function in the playback of Premiere Elements (any version) AVCHD on DVD or Blu-ray disc format on Blu-ray disc.
              It is only for Premiere Elements DVD-VIDEO on DVD where stop markers work at playback time.
              This type of situation forces the AVCHD and Blu-ray people to take their Timeline to a file which can be taken into some 3rd party software for menus which support the stop marker/stop maker like function.
              Just in case note, no more than 1 marker can occupy a given spot on the Timeline...and, if stop marker and scene marker are too close, that can spell trouble.
              Please review the above and then let me know if I have targeted what you seek or whether I am still circling the core of the question.
              Thanks.
              ATR
              • 4. Re: Menu Markers
                I am creating a DVD-Video on a DVD Disc.  Premiere Elements automatically places a Scene Marker in front of all four video clips.  I then burn the DVD.  When I load the DVD into the player, the Main Menu appears.  It gives me two choices:  Play Movie and Scene Selection.  Play Movie plays all four Scenes without going back to the Main Menu until it plays the last clip.  When I select Scene Selection, all four video clips appear individually in the Scene Menu.  However, when select a clip to play, it plays all the clips after it.  It does not return to the Main Menu.
                • 5. Re: Menu Markers
                  A.T. Romano Level 7
                  Michael Stehly
                  Thanks for the detailed reply.
                  Although Premiere Elements is automatically placing a scene marker at the beginning of each of your four clips, are you confirming that you are placing
                  a stop marker (red marker) at the end of clips 1, 2, 3, but not 4? A stop marker at the end of 4 is not needed and often causes problems during the burn to.
                  At the end of clip 1 you will have a stop marker.
                  Right next to that stop marker is the beginning of clip 2 which starts with a scene marker.
                  Leave a little space (few frames) between the stop marker at the end of clip 1 and the scene marker at the beginning of clip 2
                  and same continuing on....
                  I will be watching for your results later in the morning.
                  Thank you.
                  ATR
                  • 6. Re: Menu Markers
                    Your suggestion of placing the Stop Marker worked.  Thank you
                    • 7. Re: Menu Markers
                      A.T. Romano Level 7
                      Michael Stehly
                      Thanks for the follow up with good news "....worked."
                      As always, best wishes
                      ATR
