1 Reply Latest reply on Mar 14, 2007 9:57 AM by BorosAdam
    Navigation Structure help.
      Im new to flash, please help. I have made my main navigation inside a movie clip symbol but when i add script to direct the button... for example
      on (release) {
      It is controlling the timeline within the movie not on the main timeline. How do i script the button to navigate the main timeline, not inside the navigation movie clip??
      Thanks for any help.
        • 1. Re: Navigation Structure help.
          BorosAdam Level 1
          paths in actionscript use dot syntax and you have words _root, _parent, this to refer to timelines. _root always refers to the main timeline. [however, you should avoid using _root because ... ok, you will see later on :) ]
          so, if you have a button inside a movieclip and you want to refer to that timeline on wich that is you simply can write: this._parent.gotoAndPlay... blabla...
          try to play with these expressions a little bit since using these is core knowledge in scripting.
