3 Replies Latest reply on Mar 15, 2007 9:27 PM by ntsiii
    Loading Multiple XML files
    dsvsadvas
      Hi, in my Flex application I need to load different XML files based on different events. I don't want to preload all the data when the application initilizes. Do you know a good OOP approach for doing this? Should I create multiple HTTP Services? Can I make just one HTTP Service inscance that can be called from different scopes? How about a static class that handles the loading of data so I can use it at different scopes in my application? Your advice will be helpful. I'm a Flash designer who is learning how to program in Flex. Thanks.
