0 Replies Latest reply on Mar 14, 2007 2:48 PM by Proeliata
    RSL problems
    Proeliata
      Hi everyone,
      I have a large-ish project that I'm working on in which I'd like to make use of RSLs. I faithfully followed the directions given in the "RSL example" section of the help files. This is what I did and the result with which I did it:
      compc -sp com/foo/bar -debug=false -o bin/mylib1.swc OPBase
      Result: "Error: A file found in a source-path must have the same package structure '', as the definition's package, 'com.foo.bar'.
      When I tried deleting the package declaration from the file defining the OPBase class (that is, the "package com.foo.bar" part), the compc compiler worked, but my project would no longer compile, complaining that "A file found in a source-path must have the same package structure 'com.foo.bar', as the definition's package, ''.
      Thinking that I must be doing something wrong, I replicated exactly the structure used in the "RSL example" page in the help files, only to get the same errors.
      So, is this a bug or working as intended? Am I doing something obviously wrong?
