4 Replies Latest reply on Nov 15, 2014 9:31 PM by CHRISTIANA RAE
    Can anyone give me some insight on how to create this layout?
    CHRISTIANA RAE
      Is there a tool to turn a photo into a sketch, or do you think these handbag images were created with another application?fashion software 1 copy.jpg
        • 1. Re: Can anyone give me some insight on how to create this layout?
          Each Item is on its own layer that has layer mask that is linked to the layers content and cuts out the object.  When you move the layer content the linked mask also moves to keep the object cut out.  The layer stack order  controls the over lapping layers visibility.  So you can move around the object in layers above the background layer.
          Layer style can be added to the layers most there have drop shadows styles added.
          Composits, Montarges and collages are created with layers, layer mask, layer styles and adjustment layers, They basically the same.
          Photo Collage Toolkit
          Photoshop scripting is powerful and I believe this package demonstrates this A video showing a 5 image collage PSD template  being populates with images:
          The package includes four simple rules to follow when making Photo Collage Template PSD files so they will be compatible with my Photoshop scripts.
          1. Size the photo collage templates for the print size you want - width, height and print DPI resolution.
          2. Photo collage templates must have a Photoshop background layer. The contents of this layer can be anything.
          3. Photo collage templates must have alpha channels named "Image 1", "Image 2", ... "Image n".
          4. Photo collage templates layers above the background layers must provide transparent areas to let the images that will be placed below them show through.
          There are twelve scripts in this package they provide the following functions:
          1. TestCollageTemplate.jsx - Used to test a Photo Collage Template while you are making it with Photoshop.
          2. CollageTemplateBuilder.jsx - Can build Templates compatible with this toolkit's scripts.
          3. LayerToAlphaChan.jsx - Used to convert a Prototype Image Layer stack into a template document.
          4. InteractivePopulateCollage.jsx - Used to interactively populate Any Photo Collage template. Offers most user control inserting pictures and text.
          5. ReplaceCollageImage.jsx - use to replace a populated collage image Smart Object layer with an other image correctly resized and positioned.
          6. ChangeTextSize.jsx - This script can be used to change Image stamps text size when the size used by the populating did not work well.
          7. PopulateCollageTemplate.jsx - Used to Automatically populate a Photo Collage template and leave the populated copy open in Photoshop.
          8. BatchOneImageCollage.jsx - Used to Automatically Batch Populate Collage templates that only have one image inserted. The Collage or Image may be stamped with text.
          9. BatchMultiImageCollage.jsx - Used to Automatically Batch Populate Any Photo Collage template with images in a source image folder. Easier to use than the interactive script. Saved collages can be tweaked.
          10. BatchPicturePackage.jsx - Used to Automatically Batch Populate Any Photo Collage template with an image in a source image folder
          11. PasteImageRoll.jsx - Paste Images into a document to be print on roll paper.
          12. PCTpreferences.jsx - Edit This File to Customize Collage Populating scripts default setting and add your own Layer styles.
          Documentation and Examples
          • 2. Re: Can anyone give me some insight on how to create this layout?
            Level 5
            BELLABABE1961 wrote:
            …do you think these handbag images were created with another application?
            They look like photographs to me.
            • 3. Re: Can anyone give me some insight on how to create this layout?
              You can also select object copy the to the clipboard and past the in as layers the require no layer mask and mover the about
              • 4. Re: Can anyone give me some insight on how to create this layout?
                CHRISTIANA RAE Level 1
                Thank you so much for such detailed information, I'll give it a try.
