8 Replies Latest reply on Dec 11, 2014 7:41 AM by rkelly0137
    Why is it when i choose a fill color for my square layer, it comes out darker?
    Jackson Masterson
      Hello,
      when i make my rectangle using the rectangle tool in Photoshop CC 2014 and i try to set a fill color for it. It comes out darker? What i mean is when i try to make the color a neon blue it comes out as a "duller" blue. Like a very light purple.
      PC specs:
      Processor: Intel(R) Core(TM) i5-3230M CPU @ 2.60Hz
      RAM: 6.00 GB (5.89 usable)
      64 bit Operating System, x64 based processor
      Photoshop 2014.2.1 Release
        • 1. Re: Why is it when i choose a fill color for my square layer, it comes out darker?
          Color management - or lack of same plus potential gamut issues when you work in color modes such as CMYK. Take a pick.
          Mylenium
          • 2. Re: Why is it when i choose a fill color for my square layer, it comes out darker?
            Jackson Masterson Level 1
            Ok here it is. It keeps switching to that color when i want it to be the color in the color selector in the top right corner. Screenshot (36).png
            • 3. Re: Why is it when i choose a fill color for my square layer, it comes out darker?
              norman.sanders Most Valuable Participant
              Your mode is CMYK and that color is outside the CMYK gamut. To get the color you are after, switch to RGB
              The out-of-gamut marker  ! alerts you to that fact and shows the alternate color.
              • 4. Re: Why is it when i choose a fill color for my square layer, it comes out darker?
                Ok, when i try to color a layer it goes back to that ugly dark color. and at the top it says this RGB/8/CMYK. Screenshot (38).png
                • 5. Re: Why is it when i choose a fill color for my square layer, it comes out darker?
                  rkelly0137 Level 4
                  You're in color proof - RGB into CMYK.  Just press Ctrl/Cmd + Y, once.
                  • 6. Re: Why is it when i choose a fill color for my square layer, it comes out darker?
                    hi. i know its been a while but i have a problem again. I wanted to change the color of the drawstrings in this image (its my minecraft skin in cartoon form, just so you know) but when i did Ctrl+Y it just showed this. Please help.Screenshot (45).png
                    • 7. Re: Why is it when i choose a fill color for my square layer, it comes out darker?
                      (I edited my reply to make it more complete)
                      It seems my initial response to your inquiry was not sufficient so I will give it another try with more detail.
                      You chose, for reasons not mentioned, to prepare your work in CMYK mode. As a result you have available to you a smaller spectrum of colors from which to choose than if you worked in RGB – to which all the colors presented in the Color Picker are accessible.  To alert you to the CMYK color choice limitation, you may call on the command View > Gamut Warning, which covers with gray those colors not normally obtainable with the CMYK ink set. The comparison is shown below.
                      This smaller spectrum of colors is referred to by lithographers in part of the country as the PIG: the printing ink gamut. Note in the illustration that the color chosen in RGB is outside the CMYK PIG.
                      The reason for this difference is that the CMY printing inks, which act as filters are is not perfect. They reflect their assigned colors (which you see), but also reflect hues within the ink pigment (and other components such as vehicles and driers) that, if perfect, they would absorb.
                      Cyan ink should absorb all the R of the RGB light falling on it. It doesn’t.
                      Magenta ink should absorb all the G of the RGB light falling on it. It doesn’t.
                      Yellow ink should absorb all the B of the RGB light falling on it. It almost does.
                      How does each rate? The Cyan is the worst of the three. Magenta takes the middle spot, and Yellow is excellent.
                      Since you work in CMYK for your illustrations, I assume you have been in a printing plant. If you would like visual proof of Cyan’s limitation, the next time you visit your printer, ask him to take an ink knife and draw down Cyan straight out of the can onto a sheet of white paper. You will see that as the color gets lighter, it shifts toward gray because its color reflecting impurities neutralize the color.
                      A handy reminder of color reflection (which you see) and absorption (which you don’t see) is displayed in the Info panel: Each color in the CMY segment of the Info panel displays the color name (C, M, Y) and in its adjacent RGB panel it its right it displays the color it absorbs.
                      That is why, when working in CMYK:
                      Increasing C reduces R cast in an image
                      Increasing M reduces G cast in an image and
                      Increasing Y reduces B cast in an image
                      Conversely:
                      Reducing C increases R cast in an image
                      Reducing M increases G cast in an image and
                      Reducing Y increases Y cast in an image
                      In a offset litho plant running a CMYK job, when the subject matter requires colors outside the PIG, and client demand and budget allow, an additional “spot color”, usually specified by its PMS number, is added to the pressrun much the same way as a spot press varnish may be added.
                      A seemingly logical option with goals such as yours is to change the Cyan in the CMYK set to a PMS color that would be more helpful in producing the desired Blue, for example. True, it would, but unfortunately it would do that at the price of color accuracy of other color mixtures in the image that include the “modified” cyan. Even shifting Y’s lemon yellow to chrome yellow (Caterpillar tractor color) will affect the image. So a balanced set of CMYK colors such as those presented in the Photoshop list, is a prudent choice.
                      Now let’s get to your illustration. The blue you would like to appear in your CMYK image is not obtainable with normal printing inks. It is outside the PIG. Photoshop shows you the nearest achievable color. Barring the option to shoulder the cost of additional PMS spot colors, you must live with that limitation.
                      If the reply above answers your question, please take a moment to mark this answer as correct by visiting:https://forums.adobe.com/message/7005523#7005523 and clicking ‘Correct’ below the answer
                      • 8. Re: Why is it when i choose a fill color for my square layer, it comes out darker?
                        rkelly0137 Level 4
                        Jackson Masterson wrote:
                        ... but when i did Ctrl+Y it just showed this. Please help.
                        That's because you're fully in CMYK mode now, as well as as CMYK preview (since you hit Ctrl+Y).  See how it says it twice on the tab where the image name is?
                        Go to Image>Mode> and change CMYK to RGB.  It should take you out of CMYK preview as well.  If not, hit Ctrl+Y again.
