2 Replies Latest reply on Mar 15, 2007 8:29 AM by dennismr
    Combo Box data value
    dennismr
      I have a combo box that I've populated with a DataProvider call to a web service. The only value I've been able to display and access is the LabelField property. That allows me to display appropriate information in the box but I don't see how to access data from the web service that I wouldn't want to display in the drop down display. Is it possible to get more information than just the one field?
        • 1. Re: Combo Box data value
          Brandon Ellis Level 1
          Depending on the result format of your data (pretty much they all come down to objects) you should be able to to call your data with the property name:
          <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="init();">
          <mx:Script>
          <![CDATA[
          import mx.collections.XMLListCollection;
          import mx.controls.Alert;
          private var myXML:XML = <contacts>
          <contact>
          <name>Brandon</name>
          <state>Virginia</state>
          </contact>
          <contact>
          <name>Mark</name>
          <state>Georgia</state>
          </contact>
          <contact>
          <name>John</name>
          <state>Texas</state>
          </contact>
          </contacts>;
          private var ary:Array;
          private var xmlCol:XMLListCollection;
          private function init():void {
          xmlCol = new XMLListCollection(myXML.contact);
          contactCB.dataProvider = xmlCol;
          contactCB.addEventListener("change", contactCBChangeHandler);
          private function contactCBChangeHandler(evt:Object):void {
          Alert.show(evt.target.selectedItem.name + " is from " + evt.target.selectedItem.state);
          </mx:Script>
          <mx:ComboBox x="64" y="20" id="contactCB" labelField="name"></mx:ComboBox>
          </mx:Application>
          Since I made up the datasource I used the XMLListCollection to hold the xmlList (myXML.contact). myXML.contact is actually an object array and can be thought of in the way:
          var ary:Array = new Array(
          {name:"Brandon", state:"Virginia"},
          {name:"Mark", state:"Georgia"}l
          {name:"John", state:"Texas"}
          Just keep in mind that the object properties are the xml node names returned from your service.
          I know this isn't the greatest example but it's late.
          hope it helps some anyway.
          • 2. Re: Combo Box data value
            dennismr Level 1
            Awesome, thanks very much! I'll try this out and let you know.
            Mike
