3 Replies Latest reply on Nov 17, 2014 1:11 AM by try67
    Adding custom arguments to links
    WidgetAvenue
      This might be an easy question, but we can't find  a way for now.
      We need to create a script or plug-in that makes it easy for users to enter/edit links using a specific syntax.  This syntax is used on a pdf reader we have developed on iOS, Android, and Windows 8.
      Here is a simple example of how our pdf reader works on mobile devices:
      We do not need to reproduce this behaviour in Acrobat, but we need to make it simple for users to enter links using our syntax. So, in the example above, after entering a link to http://www.google.com using Acrobat's regular link editing tool, the user would be presented a check button where they would choose either "Open Link In Full Screen" or "Open Link Inside Pdf". When the user has made a choice, the link would be changed to either http://www.google.com/warect=full or http://www.google.com/warect=self.
      We are not sure: is it possible to develop such an interface using javascript?
      For example, is it possible to create a contextual menu which can be opened when right clicking on a link on Acrobat?
        • 1. Re: Adding custom arguments to links
          No, you can't do it using JavaScript. I mean, you can create the interface but you can't hook it up to the Link Tool. Nor can you assign an "open a web-page" command to a link using JS. You can only use it to assign "Execute a JavaScript" command.
          You can use JS, though, to create a pop-up menu that will open when a link is clicked.
          • 2. Re: Adding custom arguments to links
            WidgetAvenue Level 1
            Thanks for your answer.
            What we are trying to achieve is not to reproduce in Acrobat the behavior of our own reader. What we need is a way to make it easy to enter links in Acrobat with our specific syntax.
            I understand it's not possible to create an interface hooked up to the link tool. Now, if the user selects a link previously created with the link tool, and then starts our script using a custom menu (or whatever), is it possible inside the script to detect the selected link? And is it possible to change the destination of this link?
            • 3. Re: Adding custom arguments to links
              The answer to both questions is no. It might be possible to do it using a plugin, though. You can ask over at the Acrobat SDK forum about that.
