0 Replies Latest reply on Mar 14, 2007 10:30 AM by aekidna
    WebServices and Module problem
    aekidna
      Hi!
      I am in trouble with dynamically loaded Modules and WebServices.
      I have an application with a main container which defines services with proxy configuration.
      This application loads Modules which make use of such services, a SearchThings web service for instance.
      It happens that if I load instances of SearchThings as the first modules, everything goes well, SearchThings uses the defined services succesfully. But if I load another Module, say GrabData, which makes use of its own defined RemoteObject services, and then I load a SearchThings instance, I get an error loading wsdl within SearchThings. The fault string says that the named service does not exist.
      May anyone help?
      Thanks.
      Nicola
