5 Replies Latest reply on Mar 14, 2007 8:53 PM by ana_rad
    Opening files via Default Program
    ana_rad
      Can someone tell me why my PNG files cannot be opened with Fireworks if I try to set it as the default program in Windows? I had Version 6.0 & 8.0 installed on my machine. I was running them concurrently without a problem. After I uninstalled Fireworks 6.0 the problem occured. I couldnt no longer double click a PNG file and have it automatically open the program. When I try to re-associate the PNG extension with Fireworks it doesnt let me select the fireworks.exe program from C:\Program Files\Macromedia\Fireworks 8 directory.
      Any ideas how to fix this?
        • 1. Re: Opening files via Default Program
          Level 7
          ana_rad,
          You might try deleting the png file extension from the list of
          associated files and recreating it. That has worked for me in the past.
          alex
          • 2. Re: Opening files via Default Program
            ana_rad Level 1
            I just tried that and when I added it back in I had to use the 'select a program from a list' option because it wasnt listed in the program lsit. Therefore, i had to browse for the fireworks.exe file, once i located it, i selected it, and it does nothing. It doesnt recognise that fireworks is a program that it can use to open the file.
            • 3. Re: Opening files via Default Program
              Level 7
              Browse through some of the other file extensions and look at how the
              open command is set for them. Then try to replicate this with the png
              extension. I know for a fact that sometimes file associations can be a bear.
              alex
              • 4. Re: Opening files via Default Program
                Level 7
                via the Advanced button, that is ....
                > bear.
                • 5. Re: Opening files via Default Program
                  ana_rad Level 1
                  Thanks Alex - that worked! :-)
