1 Reply Latest reply on Nov 17, 2014 4:09 PM by Amebr
    RH11-How do I change a DOCTYPE across a project?
    zeppm Level 1
      I'm using RH11, and my employer wants to publish our software for our December 1 release in about 50% WebHelp and 50% .CHM format.    They said that they are having issues with the .chm format files having compatibility on/compatibility off with different versions of IE that our customers are using, where customers will get a "Compatibility View Settings" window depending on whether they have that on or off.  Because of that, they want me to change the beginning of each HTML file from this:
      <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
      to this:  <!DOCTYPE HTML>
      Is there a fast way to do this?  One of my pieces of software has 448 HTML topics!
      I tried search and replace, but that did not work.  They want this done regardless of whether the end release will be HTML or .chm.
      Thanks!
        • 1. Re: RH11-How do I change a DOCTYPE across a project?
          Amebr Level 4
          Find in Files should work. I tried copying the line in a test project and Find and Replace found it across all my topics.
          Make sure you have the following setup:
          Look in: <current project>
          Files of type: Text file types (*.htm ; *.html; *.txt)
          x  Include Subfolders.
          Or possibly you have line breaks inside your doctype tag in which case you could try this - take a backup of your projects and test it on a single file first!
          Find what: (\<\!doctype html(/?[^\>]+)\>)
          Replace with: <!doctype html>
          Look in: *same as above
          Files of type: * same as above
          x  Use: Regular Expressions
          HTH,
          Amber
          P.S. I just realised maybe you are accessing the wrong search and replace.
          Edit > Replace (Ctrl+H) only searches in the current topic.
          Edit > Find and Replace in Files (Ctrl+Shift+F) searches across all files in a project or a select directory/folder
