0 Replies Latest reply on Nov 17, 2014 12:24 PM by frustrared by install
    Email Button and Three dropdowns
      I have three drop down fields, and one email button. At a give time only one of dropdowns has values (email address) in it. I am using below code that works great with only one filed, is there anyway make it work with all three fields?
         // This is the form return email, It’s hardcoded
         // so that the form is always returned to the same address
         // Change address on your form
         var cToAddr = this.getField("EmailList1").value;
         // First, get the client CC email address
         var cCCAddr = this.getField("ReqEmail").value;
           // Set the subject line for the email message
         var cSubLine = "Qyestion Form"
         //  Set the body text for the email message
         var cBody = "Thank you for submitting your form.\n" +
                     "A copy would be emailed to you";
         // Send the entire PDF as a file attachment on an e-mail
         this.mailDoc({bUI: true, cTo: cToAddr, cCc: cCCAddr,
                        cSubject: cSubLine, cMsg: cBody});
      the other two dropdowns are EmailList2, and EmailList3,  user can choose an email address from only one of the dropdown fields
