5 Replies Latest reply on Nov 18, 2014 12:40 PM by kglad
    Can't create property if instance has a name
    Karaczono Level 1
      Hi
      In one FLA file I have two symbols: Symbol1 and Symbol2
      Symbol1's instance name is 's1'
      Symbol2's instance name is 's2'
      Both symbols I exported to the run time shared library
      If I add to the stage the Symbol1 and then write code: trace(s1.s2); then I can see in output: [object Symbol2]
      Next if I:
      -create new FLA file, and import those assets to it
      -import SWC of previous FLA to that one
      -add to the stage Symbol1
      -edit instance name of Symbol1 and set it to 's1'
      Everything works fine till now.
      But if I in that first FLA file where are both symbols, I edit class definition for Symbol1 and saved it as Symbol1.as
      If I test that first FLA everything is OK
      but if I test second FLA that import assets
      that also has the same code: trace(s1.s2); then I can see in output: Access of possibly undefined property s2 through a reference with static type Symbol1.
      What is wrong?
