8 Replies Latest reply on Nov 18, 2014 2:21 PM by kglad
    Sprite/constructChildren() problem
    Karaczono Level 1
      Hi
      I have two FLA files: in.fla and a.fla
      a.fla has two symbols: Symbol1 and Symbol2
      Symbol2 is added to Symbol1
      Symbol2's instance name is 's2'
      Both symbols I exported to the run time shared library
      In first frame of a.fla I wrote:
      import flash.display.MovieClip;
      var s1:MovieClip = new Symbol1;
      trace(s1.s2, 'this is trace from a.fla');
      If I test the a.fla now in output I can see: [object Symbol2] this is trace from a.fla
      Next:
      In in.fla I import those two Symbols to it
      Import SWC of a.fla to that one
      then write code in frame 1:
      var l:Loader = new Loader;
      l.contentLoaderInfo.addEventListener(Event.COMPLETE, c);
      l.load(new URLRequest('a.swf'));
      function c(e:Event):void{
          new Symbol1;
      When I test in.fla in output I can see: [object Symbol2] this is trace from a.fla
      So everything works fine till now.
      But if I edit class definition for Symbol1 in a.fla and save it as Symbol1.as then:
      When I test a.fla nothing has changed
      But in.fla gives me an error:
      ReferenceError: Error #1056: Cannot create property s2 on Symbol1.
          at flash.display::Sprite/constructChildren()
          at flash.display::Sprite()
          at flash.display::MovieClip()
          at Symbol1()
          at a_fla::MainTimeline/frame1()
          at Symbol1()
          at in_fla::MainTimeline/c()
      What is wrong?
      PS. If in a.fla in Symbol1 delete instance name for Symbol2 the error disappears;
