0 Replies Latest reply on Nov 19, 2014 4:36 AM by Ot_Gu
    recurse xml remove all but first child
    Ot_Gu
      I've tried searching for a solution and tried to adapt the code i found but I'm stuck.
      I simply want to:
      Delete all children bar the first child of all elements named "gr_name".
      I've been looking at Remove xml element using JS[CS3] and got some inspiration.
      I have the below code, which works if there is only two child elements.
      If there is three or more I have to rerun the code which removes more elements.
      I would very much appreciate if someone can help me locate the error or indicate what is missing.
      Table_Remove (myDoc);
      function Table_Remove(elm)
          for (var i = 0; i < elm.xmlElements.length; i++)
                   if(elm.xmlElements[i].markupTag.name == "gr_table")
                          for (var i2 =1; i2 < elm.xmlElements[i].xmlElements.length; i2++)
                                  elm.xmlElements[i].xmlElements[i2].remove();
                  Table_Remove(elm.xmlElements[i]);
