1 Reply Latest reply on Mar 16, 2007 9:58 AM by mclem
    drop down box
    casiew
      So does anyone know how to make a drop down box?
      and then is there an amount of items that is too many for flash files?
      Like how many items should you have in a file before it becomes too much to load?
      thanks.
      casie
        • 1. Re: drop down box
          mclem Level 1
          There are several components that come with flash if you open the component window in flash and select UI components there is the accordion, combo box, list and menu components that could all, to one degree or another, be considered drop downs.
          as far as the items in flash, do you mean items in the drop down box or images on screen...? the short answer to you question is if you build it and it takes forever to load, then yes you've probably put to much stuff in the swf.
