11 Replies Latest reply on Nov 19, 2014 12:16 PM by Trevorׅ
    How do I apply style within a text frame linked object
    hamdifem
      I'm selecting the text frame in the object I want to apply an object style
      A script can be written
      within a text frame the linked object (selected text frame)
      how object style is applied
        • 1. Re: How do I apply style within a text frame linked object
          Trevorׅ Adobe Community Professional
          Hi
          All you need is
          app.selection[0].appliedObjectStyle = app.activeDocument.objectStyles.itemByName ("Trevors Object Style");
          The below snippet will apply the style to all the anchored objects in the selection or document
          var doc = app.properties.activeDocument,
              myOnjectStyle = doc.objectStyles.itemByName ("Trevors Object Style"),
              myObjects, l;
          if (!myOnjectStyle.isValid) {
              alert ("Either add an Object Style Called:\nTrevors Object Style\nOr Make Significant Changes to The Script");
              quit ();
          app.findTextPreferences = app.changeTextPreferences = null;
          app.findTextPreferences.findWhat = "^a";
          myObjects = (app.selection && app.selection[0]).findText () || doc.findText ();
          l = myObjects.length;
          while(l--) myObjects[l].textFrames[0].appliedObjectStyle = myOnjectStyle;
          HTH
          Trevor
          • 2. Re: How do I apply style within a text frame linked object
            hamdifem Level 1
            thank you my Script you can edit?
            This script all page and all text frame run
            but I'm just select the text frame
            main ();
            function main(){
              app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
                if(app.documents.length >= 1){
                    var myDocc=app.activeDocument;
                    embeddd()
                }else{
                    alert("pleace select");
            function embeddd(){
                var frameNoo=0
                var toplamSayi=app.activeDocument.activeLayer.textFrames.length
                    for (var i=0;   i <toplamSayi; i++){
                        var islenecekTextFrame=app.activeDocument.activeLayer.textFrames.item(i)
                            for (var j=0;   j <app.activeDocument.activeLayer.textFrames.item(i).pageItems.length; j++){
                                var myNewFrame=app.activeDocument.activeLayer.textFrames.item(i).pageItems.item(j);
                               myNewFrame.appliedObjectStyle = myObjectS;
                               frameNoo++
            • 3. Re: How do I apply style within a text frame linked object
              Sorry I couldn't understand your English.
              Try to explain what you need more clearly
              • 4. Re: How do I apply style within a text frame linked object
                hamdifem Level 1
                only I selected within a text frame
                I want to apply to objects
                var myTextFrame =app.activeDocument.selection[0].textFrames.length
                for (var i=0;   i <myTextFrame.length; i++){
                myTextFrame.item(i).appliedObjectStyle = app.activeDocument.objectStyles.itemByName = myObjectStyle1;
                • 5. Re: Re: How do I apply style within a text frame linked object
                  Still not too sure what exactly you want but this should do it.
                      myObjectStyle = doc.objectStyles.itemByName ("Trevors Object Style"),
                      myObjects, l,
                      mySelection = app.selection;
                      quit ();
                  if (!mySelection) {
                      alert("NoSelection\nHave a nice day");
                      quit ();
                  mySelection = mySelection[0];
                  if (mySelection.properties.parentTextFrames) myObjects = mySelection.properties.parentTextFrames[0].findText ();
                  else if (mySelection instanceof TextFrame) {
                      myObjects = mySelection.findText();
                      if (mySelection.parent.hasOwnProperty("baseline")) myObjects = myObjects.concat.apply(mySelection.parent.findText ());
                  else myObjects = "";
                  while(l--) myObjects[l].textFrames[0].appliedObjectStyle = myObjectStyle
                  • 6. Re: How do I apply style within a text frame linked object
                    hamdifem Level 1
                    text frames in at the same time rectangle is embedded fails
                    • 8. Re: How do I apply style within a text frame linked object
                      Change the textFrames[0] to pageItems[0] on the last line
                      • 9. Re: How do I apply style within a text frame linked object
                        P.s. You can either select the particular textframe you want to apply the style to or to the parentTextFrame or to a word in the parentTextFrame
                        • 10. Re: How do I apply style within a text frame linked object
                          hamdifem Level 1
                          very simple
                          ok
                          separately, different style to the text frame (myobjectstyle1)
                          rectangle separate style (myobjectstyle2)
                          I want to apply. How do we do
                          • 11. Re: How do I apply style within a text frame linked object
                            make myObjectStyles into an array i.e.
                            myObjectStyles = [
                                            doc.objectStyles.itemByName ("Trevors Object Style2")
                            Then in the last line
                            while(l--) myObjects[l].pageItems[0].appliedObjectStyle = myObjectStyles[l % myObjectStyles.length]
