4 Replies Latest reply on Nov 23, 2014 6:12 PM by Marc Autret
    Some regexp inside ExtendScript freeze InDesign
    eutheneia
      Hello everybody!
      I am verifying that some particular regexp freezes InDesign when executed inside ExtenScript.
      For example:
           if (m = line.match(/^sort\s+((?:a(?:lphabetically)?|n(?:umerically)?)|r(?:everse)?){1,2}$/i)) { ...
      (meaning that my parser accept lines in one of these forms:
           sort alphabetically reverse
           sort numerically
           sort ar
           sort reverse numerically
      and so on...).
      Another example.
      If I use this, everything is working:
           m = line.match(/corner\s+((?:\+|\-)?\d+)(?:\s|$)/);
      but, if I add the bolded part \d*\.?:
           m = line.match(/corner\s+((?:\+|\-)?\d*\.?\d+)(?:\s|$)/);
      when executing, InDesign freezes.
      What do you think? Maybe ExtendScript contains some bug on the regexp engine? Am I wrong somewhere and I am not able to understand where? :-(
      Do you experiment the same failure than me when you execute all that?
      I am working on Indesign CS6, CC, CC 2014.
      Many thanks ...
      Roberto
        • 1. Re: Some regexp inside ExtendScript freeze InDesign
          pixxxel schubser Most Valuable Participant
          Hi eutheneia,
          what is this?
          IMHO this should be better:
          sort\s+(((alphabet|numer)ically|reverse)\s)*
          And please – show us some examples what do you hope to find with your second grep.
          • 2. Re: Re: Some regexp inside ExtendScript freeze InDesign
            eutheneia Level 1
            can match each one of these lines:
            alphabetically
            numerically
            alphabeticallyreverse
            numericallyreverse
            reversealphabetically
            reversenumerically
            but also their abbreviations:
            a
            n
            ar
            nr
            ra
            rn
            Instead,
            matches "corner " followed by a number that can be integer or floating, preceded by its optional sign and followed by a space or a linebreak.
            But I were asking something different: simply why it freezes InDesign, and if always (on every machine) it is not working, or if I have to suspect that my installation is bad.
            • 3. Re: Re: Re: Some regexp inside ExtendScript freeze InDesign
              IMHO you use a wrong syntax.
              This regex do not works in InDesign.
              Please try something like this:
              corner\s(?=[+-]?\d+(\.\d+)?(\s|$)?)
              to find e.g.
              corner 1
              or
              corner 12
              or
              corner 123.45
              Have fun
              • 4. Re: Re: Re: Some regexp inside ExtendScript freeze InDesign
                Marc Autret Level 4
                Hi eutheneia,
                Greedy quantifiers like +, *, or {m,n} cause issues in InDesign—in particular, in CS6 and later—when mixed with optional sub-patterns. For instance, a very simple way to create an infinite loop in CS6-CC is:
                alert( /(aA?|bB?)+$/.test("bx") ); // CS4: FALSE ; CS6-CC: FREEEEZE!
                or even:
                alert( /(a|bB?)+$/.test("bx") );   // CS4: FALSE ; CS6-CC: FREEEEZE!
                Those "explosive quantifiers" are not properly addressed due to various backtracking bugs which Adobe devs don't seem to be aware of. Another fact is that ExtendScript CS6-CC doesn't interpret the scheme /((A|B)|C)/ the right way:
                alert( /^((a|b)|c)+$/.test("ac") ); // CC: FALSE!
                alert( /^((a|b)|c)+$/.test("ca") ); // CC: TRUE
                // Interestingly:
                alert( /^(c|(a|b))+$/.test("ac") ); // CC: TRUE
                alert( /^(c|(a|b))+$/.test("ca") ); // CC: TRUE
                But, in fact, /((A|B)|C)/ is equivalent to /(A|B|C)/ —isn't it? So your original pattern is (although without your consent!) very similar to:
                /^sort\s+(a(?:lphabetically)?|n(?:umerically)?|r(?:everse)?){1,2}$/i
                which does not solve the problem, but makes things easier to follow.
                [In addition, the repeated capturing group (...){1,2} will only capture the last iteration—which is probably not what you expect.]
                In your case, the best way to avoid explosive quantifiers (and those good old InDesign bugs!) is to “flatten” the alternatives:
                (a|alphabetically|n|numerically|r|reverse){1,2}
                At this point freezing and bad results are gone, but your pattern still doesn't address the original goal.
                For all these reasons, and probably a few more, I think you should change your approach. Regex are based on (in)finite state automata and should be used for clean pattern matching, not for if-then-else parsing ;-)
                IMHO you should use rules, progressive steps, and divide your syntactic problem into smaller pieces.
                Marc
