1 Reply Latest reply on Nov 19, 2014 2:51 PM by ophello
    Multiple conditional using AppleScript in Indesign — won't work?
    ophello
      When I enter in a height and width of, say, 5 inches, it returns with a build size that doesn't make sense, according to the logic gate I built. Here's a stripped-down snippet of the code I wrote that should work in InDesign CS6. Any help would be greatly appreciated.
      tell application "Adobe InDesign CS6"
      activate
      set myDoc to active document
      set origLevel to user interaction level of script preferences
      set user interaction level of script preferences to interact with all
      set myDialog to make dialog with properties {name:"Make Template", can cancel:true}
      tell myDialog
      tell (make dialog column)
      tell (make border panel)
      make static text with properties {static label:"Width:", min width:60}
      make static text with properties {static label:"Height:", min width:60}
      make static text with properties {static label:"Bleed:", min width:60}
      end tell
      set myWidth to make text editboxes with properties {edit contents:"", min width:60}
      set myHeight to make text editboxes with properties {edit contents:"", min width:60}
      set myBleed to make text editboxes with properties {edit contents:"", min width:60}
      end tell
      make static text with properties {static label:"in", min width:0}
      end tell
      make static text with properties {static label:"", min width:25}
      end tell
      end tell
      end tell
      end tell
      set userResponse to show myDialog
      if userResponse is true then
      set docWidth to edit contents of myWidth as string
      set docHeight to edit contents of myHeight as string
      set docBleed to edit contents of myBleed as string
      destroy myDialog
      else
      destroy myDialog
      error number -128
      end if
      set bigDim to docWidth as string
      if docHeight > docWidth then
      set bigDim to docHeight as string
      end if
      set buildSize to 1
      if bigDim > 216 and bigDim ≤ 432 then
      set buildSize to 2
      else if bigDim > 432 and bigDim ≤ 864 then
      set buildSize to 4
      else if bigDim > 864 and bigDim ≤ 2160 then
      set buildSize to 10
      end if
      set newWidth to (docWidth / buildSize)
      set newHeight to (docHeight / buildSize)
      set newBleed to (docBleed / buildSize)
      tell myDoc
      set document bleed top offset of document preferences to newBleed
      set page width of document preferences to newWidth
      set page height of document preferences to newHeight
      end tell
      set user interaction level of script preferences to origLevel
      end tell
