2 Replies Latest reply on May 8, 2015 5:27 AM by KerryEmery
    Using Photoshop CS6 and after printing approx. 10 cards on an Epson R3000 printer the program gives me a dialog box saying "There was an error opening your printer. Printing functions will not be available until you have selected a printer and reopened an
    wcpeters
      Using Photoshop CS6 and after printing approx. 10 cards on an Epson R3000 printer the program gives me a dialog box saying "There was an error opening your printer. Printing functions will not be available until you have selected a printer and reopened any documents."  Even after closing and reopening the program, the print command is greyed out so I cannot select any printer. This also happens with a Brother laser printer. Both printers will produce a test page out side of the Adobe product. Help!
        • 2. Re: Using Photoshop CS6 and after printing approx. 10 cards on an Epson R3000 printer the program gives me a dialog box saying "There was an error opening your printer. Printing functions will not be available until you have selected a printer and reopene
          KerryEmery
          I cannot get any help either.  I get the message "There was an error opening your printer. Printing functions will not be available until you have selected a printer and reopened any documents."  I have reinstalled all drivers, powered off/on all printers (2 of them - a Brother HL - 4040cn and an Epson Stylus Pro 7890 - which all worked fine until this morning).  There appears to be no path to a solution.  I have read all the forums and tried about 20 different suggestions all to no avail.  Reboots, changing cables, reinstalling printers and drivers and Photoshop CS6 - ALL TO NO AVAIL.  On a macbook pro retina with 10.10.3.  This issue is out there and some get solutions - but not all - that's my crowd...the not all crowd.  I have yet to be able to print from CS6 any more.  This is a show stopper and my patience is wearing thin.  And I'm tired of stupid questions like "is your printer powered on?" give me a break.  This appears to be an adobe photoshop cs6 problem - as I can print from every other application.  Anyone have any ideas?  Adobe should have something?... Adobe system  info below:
          Adobe Photoshop Version: 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00) x64
          Operating System: Mac OS 10.10.3
          System architecture: Intel CPU Family:6, Model:58, Stepping:9 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
          Physical processor count: 4
          Logical processor count: 8
          Processor speed: 2300 MHz
          Built-in memory: 8192 MB
          Free memory: 4665 MB
          Memory available to Photoshop: 7059 MB
          Memory used by Photoshop: 70 %
          Image tile size: 1024K
          Image cache levels: 4
          OpenGL Drawing: Enabled.
          OpenGL Drawing Mode: Advanced
          OpenGL Allow Normal Mode: True.
          OpenGL Allow Advanced Mode: True.
          OpenGL Allow Old GPUs: Not Detected.
          OpenGL Version: 2.1 NVIDIA-10.2.7 310.41.25f01
          OpenCL Version:
          Video Card Vendor: NVIDIA Corporation
          Video Card Renderer: NVIDIA GeForce GT 650M OpenGL Engine
          Display: 2
          Display Depth:= 32
          Display Bounds:=  top: 1072, left: 140, bottom: 1950, right: 1580
          Video Renderer ID: 16918311
          Video Card Memory: 1024 MB
          Video Rect Texture Size: 16384
          OpenCL Version: 1.2 (Feb 27 2015 01:29:10)
          Display: 1
          Main Display
          Display Depth:= 32
          Display Bounds:=  top: 0, left: 0, bottom: 1050, right: 1680
          Serial number: 92629107631240972642
          Application folder: KerrysHD:Applications:Adobe Photoshop CS6:
          Photoshop scratch has async I/O enabled
          Scratch volume(s):
            KerrysHD, 232.6G, 19.7G free
          Required Plug-ins folder: KerrysHD:Applications:Adobe Photoshop CS6:Adobe Photoshop CS6.app:Contents:Required:
          Primary Plug-ins folder: KerrysHD:Applications:Adobe Photoshop CS6:Plug-ins:
          Additional Plug-ins folder: not set
          Installed components:
             adbeape.framework   adbeape   3.3.8.19346   66.1025012
             AdbeScriptUIFlex.framework   AdbeScriptUIFlex   6.2.29.18602   66.490082
             adobe_caps.framework   adobe_caps   6.0.29.0   1.276181
             AdobeACE.framework   AdobeACE   2.19.18.19243   66.492997
             AdobeAGM.framework   AdobeAGM   4.26.17.19243   66.492997
             AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.7.101.18636   66.26830
             AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.7.101.18636   66.26830
             AdobeBIB.framework   AdobeBIB   1.2.02.19243   66.492997
             AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   66.492997
             AdobeCoolType.framework   AdobeCoolType   5.10.31.19243   66.492997
             AdobeCrashReporter.framework.framework   AdobeCrashReporter   6.0.20120201
             AdobeExtendScript.framework   AdobeExtendScript   4.2.12.18602   66.490082
             AdobeJP2K.framework   AdobeJP2K   2.0.0.18562   66.236923
             AdobeLinguistic.framework      17206
             AdobeMPS.framework   AdobeMPS   5.8.0.19463   66.495174
             AdobeOwl.framework   AdobeOwl   4.0.93   66.496052
             AdobePDFL.framework   AdobePDFL   10.0.1.18562   66.419471
             AdobePDFSettings.framework   AdobePDFSettings   1.4
             AdobePIP.framework   AdobePIP   6.0.0.1654
             AdobeScCore.framework   AdobeScCore   4.2.12.18602   66.490082
             AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
             AdobeXMP.framework   AdobeXMPCore   66.145661   66.145661
             AdobeXMPFiles.framework   AdobeXMPFiles   66.145661   66.145661
             AdobeXMPScript.framework   AdobeXMPScript   66.145661   66.145661
             ahclient.framework   ahclient   1.7.0.56
             aif_core.framework   AdobeAIF   3.0.00   62.490293
             aif_ocl.framework   AdobeAIF   3.0.00   62.490293
             aif_ogl.framework   AdobeAIF   3.0.00   62.490293
             AlignmentLib.framework   xcode   1.0.0.1
             amtlib.framework   amtlib   6.0.0.75
             boost_date_time.framework   boost_date_time   6.0.0.0
             boost_signals.framework   boost_signals   6.0.0.0
             boost_system.framework   boost_system   6.0.0.0
             boost_threads.framework   boost_threads   6.0.0.0
             Cg.framework   NVIDIA Cg
             CIT.framework   CIT   2.0.5.19287   145486
             data_flow.framework   AdobeAIF   3.0.00   62.490293
             dvaaudiodevice.framework   dvaaudiodevice   6.0.0.0
             dvacore.framework   dvacore   6.0.0.0
             dvamarshal.framework   dvamarshal   6.0.0.0
             dvamediatypes.framework   dvamediatypes   6.0.0.0
             dvaplayer.framework   dvaplayer   6.0.0.0
             dvatransport.framework   dvatransport   6.0.0.0
             dvaunittesting.framework   dvaunittesting   6.0.0.0
             dynamiclink.framework   dynamiclink   6.0.0.0
             FileInfo.framework   FileInfo   66.145433   66.145433
             filter_graph.framework   AdobeAIF   3.0.00   62.490293
             hydra_filters.framework   AdobeAIF   3.0.00   62.490293
             ICUConverter.framework   ICUConverter   3.61   "gtlib_3.0" "." "16615"
             ICUData.framework   ICUData   3.61   "gtlib_3.0" "." "16615"
             image_compiler.framework   AdobeAIF   3.0.00   62.490293
             image_flow.framework   AdobeAIF   3.0.00   62.490293
             image_runtime.framework   AdobeAIF   3.0.00   62.490293
             LogSession.framework   LogSession   2.1.2.1652
             mediacoreif.framework   mediacoreif   6.0.0.0
             PlugPlug.framework   PlugPlug   3.0.0.383
             UpdaterNotifications.framework   UpdaterNotifications   6.0.0.24   "6.0.0.24"
             wrservices.framework
          Optional and third party plug-ins: NONE
          Plug-ins that failed to load: NONE
          Flash:
             Mini Bridge
             Kuler
          Installed TWAIN devices: NONE
