Hi.
I tried and searched the whole day.
I even started to check adobe edge animate for help,
but until now i couldn´t find a solution.
Hopfully someone can help me.
Here´s the idea:
I want to create a clean and simple website.
There should be images one below the other.
When the visitor hovers over one images, it should disappear (fade out).
Behind this picture is a slideshow in the same format.
When the cursor hovers of the area, the picture appears again (fade in).
Another idea is, it is a slideshow, which starts when you mouseover
and stops and shows the first picture when you mouesout the area.
There should be no buttons or anything.
Sounds easy, but I found no solution.
Is there a possibility?
Regards,
Jan
You can try using compositions , setup the active state for triggers as transparent and just opposite for target containers. Same for all.
Sanjit
