1 Reply Latest reply on Nov 20, 2014 2:29 PM by Carl Von Stetten
    Should ColdFusion <cfoutput> tags be placed inside other tags?
    up4spam
      Which of these examples is preferred?  Is the other acceptable?
      ex. A: <cfoutput><img src="#imgurl#"></cfoutput>
      ex. B: <img src="<cfoutput>#imgurl#</cfoutput>">
        • 1. Re: Should ColdFusion <cfoutput> tags be placed inside other tags?
          Carl Von Stetten Adobe Community Professional & MVP
          Personally, I would choose example A as it is cleaner to read.  Also, if I needed to populate multiple attributes of the <img> or other HTML tag, wrapping each individual attributes value in <cfoutput> tags would be silly.
          However, it really depends on personal taste and the context of the situation.  If possible, I try to avoid peppering a page with opening and closing <cfoutput> tags and instead wrap as much display code as possible in a single <cfoutput>.  Also, if you are outputting the contents of a query in a loop-like fashion ( <cfoutput query=""> ), then I'd only have one <cfoutput> tag (unless I was using the grouping feature of cfoutput, in which case I'd have nested <cfoutput> tags).
          -Carl V.
