I am attempting to download and install about 6 different updates that showed up when I started up CF 10 Admin. My server has MS Server 2003 installed and there isn't much chance the customer will upgrade it in the near future. The server is next door to my office, but we don't have KVMs installed and I can access it via Terminal Services. The process for downloading and installing these updates is taking forever. Could this issue be due to the fact that I'm using Terminal Services? Thanx.
To manually apply the update, can you try the following steps:-
1. Download the update from http://download.adobe.com/pub/adobe/coldfusion/hotfix_014.jar?
2. Copy the jar file to {cf_install}\jre\bin\.
3. Launch Command prompt as Administrator.
4. Browse to the location mentioned in Step 2 and type this command “java –jar hotfix_014.jar”
5. It will launch the update window. Follow the on screen instructions
Regards,
Anit Kumar
Regards,
Anit Kumar
They finally completed. Oracle is hogging resources and nothing is being done, other than the database is up. I am currently up to date. Thank you for the input.
To clarify, Anit provided the way to manually download the update and install it (as opposed to using the updater built into ColdFusion Admnistrator). So you could download it on your machine and then copy it to your server and install it from there manually.
Also, you don't have to download every update and install them sequentially. Each update is cumulative, so just download the latest one (Update 14 is the latest). Make sure you rebuild the web connectors as directed after the installation is complete (if you are using IIS).
-Carl V.
Old habit... Oracle does updates sequentially. Live and learn. Thanx.
