3 Replies Latest reply on Dec 22, 2015 8:22 PM by Chinnadk
    Group Objects
    danup
      Hi All,
      Is there a way to select group item based on placed image name? I have a document containing numbers of boxes that I need to select and export.
      There are three frames. 1 text frame and 2 graphic frames. Tick mark image name is tick_icon.eps and background image name is green_bg.eps.
      I need to select it through script based on graphic name. Needed help!
      Regards,
      DanuP
        • 1. Re: Group Objects
          Kramer@Filson
          try using a Script Label to identify each element that will be sought by the script.
          • 2. Re: Group Objects
            david_p Level 1
            This would be the general approach in AppleScript - get a reference to the link via the file name, then navigate up the link's parental hierarchy to find the group.
            tell application "Adobe InDesign CC 2015"
              tell document 1
              set theLinks to links whose name = "tick_icon.eps"
              set theLink to item 1 of theLinks
              set theParent to parent of theLink --parent should be PDF
              set theGrandparent to parent of theParent --parent should be rectangle
              set theGreatGrandparent to parent of theGrandparent --parent should be group
              if class of theGreatGrandparent is group then
              select theGreatGrandparent
              end if
              end tell
            end tell
            • 3. Re: Group Objects
              Chinnadk Level 4
              try this,
              var doc = app.activeDocument;
              var links = doc.links;
              for(var i=0;i<links.length;i++)
                      if(links[i].name == "test.eps")
                              var grp = links[i].parent.parent.parent;
              Regards,
              Chinna
