5 Replies Latest reply on Nov 25, 2014 3:47 PM by areohbee
    Show in finder (multiple files)
    magicgenie Level 1
      Hi everybody
      quick question.
      The D800 raws are quite big, I would like to throw away the RAW files I don't need.
      I have for example 150 RAWs, if I view by 'less than 5 star', I can see all the raw files I do not need, but the 'show in finder' works for only one file I believe?
      Is there a way to show all the RAWs I don't want in finder, then I can quickly grab them and throw them in the waste basket.
      Hope to hear from you.
      Many thanks.
      Alex
        • 1. Re: Show in finder (multiple files)
          dj_paige Level 10
          You can delete these files from Lightroom. Select them, then press delete.
          • 2. Re: Show in finder (multiple files)
            You don't want to delete files in Finder. If you do that Finder will still retain the preview and report the image as missing. Finder is looking at the same image that Lightroom is. So simply delete the file using Lightroom.
            • 3. Re: Show in finder (multiple files)
              magicgenie Level 1
              No no, i've not been clear. I want to delete a number of files at the same time, in one step.
              Apologies.
              I know the correct way to delete / remove files.
              What I mean is:
              How do I get LR to show me where a number of files live on my hard drive and select them. (Then in the hard drive I can delete them.)
              Using 'show in finder' is great, it shows me where a file lives and I can delete it.
              What if, i'm searching in a smart folder for images that are less than 5 star, as an example, i locate these images then want to delete them, i get the error message, 'cannot delete / remove files directly from a smart folder'.
              If i could tell LR to simply show me where a number of files live (not ONLY one file) on my computer, i could happily then delete them.
              Showing the file as missing does not concern me.
              Is it any clearer?
              • 4. Re: Show in finder (multiple files)
                dj_paige Level 10
                Yes, its clearer now, and it would have been very helpful is you had expressed these details at the beginning.
                So, in your smart collection, select all of the photos to be deleted, then press X. Select "All Photographs", then Photo->Delete Rejected Photos.
                • 5. Re: Show in finder (multiple files)
                  areohbee Level 6
                  Using splat-delete, you can (I often do) delete photos whilst in a collection or smart collection.
                  Caveat: only works in library module, not develop module (curses..).
                  Windows: ctrl-shift-alt-delete (I'm sure).
                  Mac: cmd-shift-option-delete (I *think*).
                  It won't prompt prior to deletion, so consider yourself forewarned, BUT it does put images in recycle-bin/trash (if volume supports it), and will assure deleted photos are removed from publish services etc.
                  'X' to reject then delete is safer, but splat-delete is quicker.
                  Cheers,
                  Rob
