8 Replies Latest reply on Nov 28, 2014 1:38 PM by Szalam
    An output module failed. The file may be damaged or corrupted.
    PoniesFiM
      Whenever I try to render something in After Effects CC 13.1.1, an error message pops up, saying "After Effects error: Rendering error while writing to file '[not going to disclose]' An output module failed. The file may be damaged or corrupted (-1610153464)."
      Screenshot of the error message:
      I tried reinstalling QuickTime (7), repaired it, updated After Effects to the latest version(as I am writing this), checked firewall software, and used other formats such as AVI.
      Adobe Media Encoder (CC 2014-latest version) won't work with me, either.
      I sent the composition to Adobe Media Encoder, and this is what I got, no progress here.
      Screenshot:
      It took a while to connect to the dynamic link server, and failed.
      This is a log of what has happened in Adobe Media Encoder.
      - Source File: C:\Users\Default.BronyGue\Documents\not done\pinkcoverart_AME\tmpAEtoAMEProject-Pink Intro1.aep
      - Output File: C:\Users\Default.BronyGue\Documents\not done\pinkcoverart_AME\Pink Intro.mp4
      - Preset Used: YouTube HD 720p 29.97
      - Video: 1280x720 (1.0), 29.97 fps, Progressive
      - Audio: AAC, 320 kbps, 48 kHz, Stereo
      - Bitrate: VBR, 2 pass, Target 5.00 Mbps, Max 5.00 Mbps
      - Encoding Time: 00:00:12
      06/29/2014 02:29:14 PM : Encoding Failed
      The Operation was interrupted by user
      (no need to worry about the above part)
      - Source File: C:\Users\Default.BronyGue\Documents\not done\moddedchill_AME\tmpAEtoAMEProject-montage1.aep
      - Output File: C:\Users\Default.BronyGue\Videos\chilledup.wmv
      - Preset Used: Custom
      - Audio: Windows Media Audio 10 Professional, 96000 Hz, Stereo, 24 bit
      - Bitrate: CBR, 2 pass, Max 10000.00 kbps
      - Encoding Time: 00:01:42
      11/22/2014 12:24:39 AM : Encoding Failed
      - Output File: C:\Users\Default.BronyGue\Videos\chilledup.mpg
      - Video: 1280x720, 29.97 fps, Progressive, Quality 75
      - Audio: MPEG Audio, 384 kbps, 48 kHz, Stereo, 16 bit
      - Bitrate: VBR, 1 Pass, Min 4.00, Target 15.00, Max 18.50 Mbps
      - Encoding Time: 00:00:11
      11/22/2014 12:52:11 AM : Encoding Failed
      - Encoding Time: 00:00:51
      11/22/2014 12:53:51 AM : Encoding Failed
      Export Error
      Error compiling movie.
      Unknown error.
      - Encoding Time: 00:00:46
      11/22/2014 08:39:46 AM : Encoding Failed
      Export Error
      Unknown error.
      - Source File: C:\Users\Default.BronyGue\Documents\not done\moddedchill_AME\tmpAEtoAMEProject-montage4.aep
      - Output File: C:\Users\Default.BronyGue\Documents\not done\moddedchill_AME\montage.mpg
      - Preset Used: Match Source - High bitrate
      - Video:
      - Audio:
      - Bitrate:
      - Encoding Time: 00:00:00
      11/22/2014 10:06:45 AM : Encoding Failed
      Could not read from the source. Please check if it has moved or been deleted.
      I need some help! Any solutions?.
      Computer Specs:
      AMD FX-6300
      8GB 1600MHz DDR3 RAM
      NVIDIA GeForce GTX 650 Ti BOOST
      1TB 7200RPM Hard Drive
      Windows 8.1 Update 1(with latest updates)
      EDIT(11/23/2014 8:31PM PST): For some reason, other projects work for me just fine. I am not sure why it is not working on one project.
      Screenshot of a new project other than this I am rendering at the time of writing this edit:
