4 Replies Latest reply on Mar 16, 2007 5:48 PM by balote
    selection box not working
    balote Level 1
      i was asked to edit some code
      one of the selection boxes wasnt working and was not updating the db at all
      here is the code snippet
      <!--- the CFC code being called
      this basically puts together the values which are valid for display in the selection box
      then returns it to the invoker
      <CFFunction name = "Sel_SpecifiedDateFlag" output = "false" returntype = "string" access = "public">
      <!--- 引数の定義 --->
      <CFArgument name = "prm_SelID" required = "true">
      <CFSet res1 = "">
      <!--- コンボリストのID設定(一元管理)--->
      <cfset id = 8>
      <CFQuery name = "query1" datasource = "#APP_DB_DSN#">
      select code , COALESCE(code::text,'') || ':' || COALESCE(name,'') as name
      from tblpmdsetcomblist
      where valid_flag = 1
      and id = #id#
      order by sort,code
      </CFQuery>
      <CFQuery name = "query2" datasource = "#APP_DB_DSN#">
      select code from tblpmdsetcomblist
      and id = #id#
      and default_flag = 1
      </CFQuery>
      <!--- 念のため、デフォルト確認 --->
      <CFIf query2.RecordCount NEQ 1>
      <CFReturn "<font color='red'><strong>リストテーブルデフォルトエラー</strong></font>">
      </CFIf>
      <!--- prm_SelIDがNullの時のデフォルトを設定 --->
      <CFIf prm_SelID eq "">
      <CFSet prm_SelID = #query2.code#>
      </CFIf>
      <CFLoop Query="query1">
      <CFSet res1 = res1 & "<OPTION Value='#code#'">
      <CFIf Compare(code , prm_SelID) eq 0>
      <CFSet res1 = res1 & " SELECTED">
      </CfIf>
      <CFSet res1 = res1 & ">">
      <CFSet res1 = res1 & #name#>
      <CFSet res1 = res1 & "</OPTION>#chr(10)#">
      </CFLoop>
      <CFReturn res1>
      </CfFunction>
      <!--- this is the code that invokes the CFC code above and displays it as well
      <CFInvoke Component="component.selbox" Method="Sel_Plusoneflag" ReturnVariable="getstr">
      <CFInvokeArgument name="prm_SelID" Value="#plus_one_flag#">
      </CFInvoke>
      <select name="plus_one_flag" Size=1>
      <CFOutput>#getstr#</CFOutput>
      </select>
      <!--- this is what #getstr# looks like when viewed via page source viewer
      <OPTION Value='0' SELECTED>0:プラフワン不可</OPTION>
      <OPTION Value='1'>1:プワスワン可</OPTION>
      </select>
      i checked all the sources of the problem which are obvious to me but found none :(
      btw the ascii characters in the code are japanese characters if youre not seeing them properly
        • 1. Re: selection box not working
          Level 7
          in the code you posted there is no code for updating the db...
          plus:
          > and id = #id#
          > order by sort,code
          > </CFQuery>
          there is no 'sort' column pulled from the db or aliased by that name as
          it appears in the order by clause in the query above...
          you did not post any code for the 'Sel_Plusoneflag' function in your
          cfc... did you post a wrong function or should you change the method's
          name in the cfinvoke?
          > none :(
          and what's the actual problem you are facing? the select box still not
          working (HOW is it not working? - not displaying/displaying wrong data?)
          or something else?
          Azadi Saryev
          Sabai-dee.com
          http://www.sabai-dee.com
          • 2. Re: selection box not working
            balote Level 1
            i posted the wrong code, here is the correct one
            <CFFunction name = "Sel_Plusoneflag" output = "false" returntype = "string" access = "public">
            <!--- 引数の定義 --->
            <CFSet res1 = "">
            <cfset id = 6>
            its all the same from that point on
            the problem with the selection box is when you choose an option (only two; 0 or 1) then submit it, it doesnt show up in the database, a new record is placed but the plus_one_flag field is null
            • 3. Re: selection box not working
              Level 7
              OK. can you also please post the code that inserts/updates record in the
              db? since your select box displays on the page, then the problem must be
              in the update/insert code...
              Azadi Saryev
              Sabai-dee.com
              Vientiane, Laos
              • 4. Re: selection box not working
                balote Level 1
                thanks again sir, ive found the problem in the template that submits all the data to the db, i was looking at the wrong place after all.
                its all working good now :)
