6 Replies Latest reply on Nov 25, 2014 4:45 AM by Henry 'Pi' James
    Find and move text to existing anchored frame
    Henry 'Pi' James
      I have a large text story spanning across many pages. It contains a number of paragraphs that have the following content:
      [anchor character for an existing, but empty anchored text frame][leading text containing NO tab][TAB][middle text containing NO tab][TAB][trailing text containing NO tab][anchor character for another existing, but empty anchored text frame]
      I need a script (preferably Javascript) that:
      1. Find any paragraph that starts with an anchor character;
      2. Find and cut the leading text between the anchor character and the first TAB after it;
      3. Paste the leading text into the text frame anchored at the beginning of the paragraph;
      4. In the same paragraph, find the trailing text between the second (and last) TAB and the second (and last) anchor character at the end of the paragraph;
      5. Paste the trailing text into the text frame anchored at the end of the paragraph;
      6. Repeat 1.-5. for all paragraph in the same story that starts with an anchor character.
      I am an advanced JS programmer, but new to CreativeSuite scripting. I've kind of figured out how to search for certain text, and I know that the `parent` of an anchored object is a `Character` - but now to I access the content of an anchored object from its parent character?
        • 1. Re: Find and move text to existing anchored frame
          Henry 'Pi' James Level 1
          I got it!
          function movetoanchored(find) {
            find.characters.itemByRange(1, -1).select();
            app.cut();
            var myStory = app.selection[0].parentStory;
            var myIndex = app.selection[0].index;
            var myAnchor = myStory.characters[myIndex - 1];
            var myFrame = myAnchor.textFrames[0];
            app.select(myFrame.parentStory.insertionPoints.item(0));
            app.paste();
          function main() {
            app.findGrepPreferences = app.changeGrepPreferences = null;
            app.findGrepPreferences.findWhat = "^~a.*?\\t";
            while (true) {
              var myFinds = app.activeDocument.findGrep();
              if (myFinds.length == 0) return;
              movetoanchored(myFinds[0]);
          main();
          • 2. Re: Find and move text to existing anchored frame
            Jump_Over Level 5
            Does it work with your second TAB-text-ANCHOR sequence?
            You should change preferences for "\\t[^\\t]+~a$" and set second anchored frame contents as find.characters.itemByRange(0,-2)
            (last character is an Anchor parent of course)
            You could use text.move() method to omit UI selection and display procedures.
            While moving keep objects compatibility (texts2texts, words2words etc., ie:
            find.characters.itemByRange(1,-1).texts[0].move(LocationOptions.BEFORE, mFrame.texts[0])
            Jarek
            • 3. Re: Re: Find and move text to existing anchored frame
              Moving the trailing text works on the same principle as the leading text, so that's no problem.
              About using `move`: I'd prefer it over copy/paste of course, but this didn't work:
                var myAnchor = find.characters[0].texts[0];
                var myText = find.characters.itemByRange(1, -1).texts[0];
                myText.move(LocationOptions.before, myAnchor.textFrames[0].texts[0])
              It reports "Cannot move the text to the given location". Any idea why?
              • 4. Re: Find and move text to existing anchored frame
                Jump_Over Level 5
                Possibly it tries to move anchored box with text all together.
                Try to replace characters with insertionPoints - I mean:
                myText = find.insertionPoints.itemByRange(1,-1).text[0];
                Jarek
                • 5. Re: Re: Re: Find and move text to existing anchored frame
                  Never mind, the sample text I used for testing had some problem. Now it works:
                    var myFrame = find.characters[0].textFrames[0];
                    myText.move(LocationOptions.atBeginning, myFrame);
                  • 6. Re: Re: Find and move text to existing anchored frame
                    Further improved:
                      myText.move(LocationOptions.AT_BEGINNING, myFrame);
                    function main() {
                      app.findGrepPreferences.findWhat = "^~a\\S+";
                      var myFinds = myStory.findGrep(true);
                      for (i = 0; i < myFinds.length; i++) movetoanchored(myFinds[i]);
                      Window.alert(myFinds.length + " moves performed");
                    app.doScript(main, ScriptLanguage.JAVASCRIPT, undefined, UndoModes.ENTIRE_SCRIPT, "MoveToAnchored");
