4 Replies Latest reply on Aug 10, 2006 12:29 PM by Newsgroup_User
    trigger event using number pad?
    kyleg
      Does anyboy know how to use the number pad numbers as triggers. I can get enter/return to work, but not the numbers (only the numbers on the top row of keyboard work. Need to use the numberpad. Are these considered special characters?
      here is what I am using for a test
      if keyPressed("6") then member("you 6").text="you hit 6"
      if keyPressed(RETURN) then member("you ENTER").text="you hit ENTER
      any ideas would be appreciated
        • 1. Re: trigger event using number pad?
          Level 7
          of
          > characters?
          keyPressed cannot distinguish between numpad kays and the ones at the top,
          it only cares about the actual ASCII value that comes in, which will depend
          on whether the user has NumLock on or not. In order to distinguish them,
          you need to use the keyCode. The keyCode values for the numpad are as
          follows:
          . - 65
          * - 66
          - - 70
          / - 77
          + - 78
          = (Mac only) - 81
          0 - 82
          1 - 83
          2 - 84
          3 - 85
          4 - 86
          5 - 87
          6 - 88
          7 - 89
          8 - 91
          9 - 92
          In order to access them, you need to have an "on keyDown" handler, like so:
          on keyDown
          put the keyCode
          end
          • 2. trigger event using number pad?
            kyleg Level 1
            A really strange thing is happening
            I found this example and works in authoring view but not as projector or shockwave?
            note this is in the moviescript so it is available at anytime during runtime
            --This handler checks if a key was pressed.
            --it uses a case statement to check the value of "the keyCode"
            --when a keyCode equals a value the handler triggers
            --remember that these values are "keyCode" commented as ASCI
            on keyDown
            case (the keyCode) of
            82 : member("you 0").text="you hit 0" --0 /play
            65 : member("you .").text="you hit ."--. / pause
            36 : sprite(4).ink=36 & member("you ENTER").text="you hit ENTER" -- enter
            88 : member("you 6").text="you hit 6"--6 /jump ahead
            86 : member("you 4").text="you hit 4"--4 /jump back
            end case
            end
            what is strange is that the key code of 36 that has the ink change works when this thing is compiled as .exe or .dcr
            Below is actually a 2nd question:
            what does not work (because I have the wrong syntax i guess), is running both events off of key code 36. With if then statements you could use an "&" as the seperater and have more than 1 thing happen. Can this even be done with case within Lingo?
            reccomendations?
            • 3. Re: trigger event using number pad?
              kyleg Level 1
              It seems that case statements using num keys have issues at runtime for some events.
              I have some luck with this method instead -------longer but works
              on keyDown
              if the keyCode = 82 then member("you 0").text="you hit 0" --num0 /play
              if the keyCode = 29 then member("you 0").text="you hit 0" --0 / play
              if the keyCode = 76 then member("you ENTER").text="you hit ENTER"--num enter
              if the keyCode = 36 then member("you ENTER").text="you hit ENTER"--enter
              -- if keyPressed(RETURN) then member("you ENTER").text="you hit ENTER"--enter
              if the keyCode = 36 then sprite(4).ink=6 -- xtra action for enter
              if the keyCode = 65 then member("you .").text="you hit ."-- num. / pause
              if the keyCode = 47 then member("you .").text="you hit ."--. / pause
              if the keyCode = 88 then member("you 6").text="you hit 6"-- num6 / next
              if the keyCode = 22 then member("you 6").text="you hit 6"-- 6 / next
              if the keyCode = 86 then member("you 4").text="you hit 4"-- num4 / previous
              if the keyCode = 21 then member("you 4").text="you hit 4"-- 4 / previous
              end if
              end if
              end if
              end if
              end if
              end if
              end if
              end if
              end if
              end if
              end if
              end
              for anybody wondering ---- 76 is the keycode for numpad's enter. This is not documented and can not be tested with the message window as numb enter is keyboard shortcut for stop running current project.
              I used this to find it.
              on keydown
              member("findit").text = "" & the keyCode
              thanks Darrel for your earlier help!
              • 4. Re: trigger event using number pad?
                Level 7
                > on keyDown
                > 82 member("you 0").text="you hit 0" --0 /play
                > 65 member("you .").text="you hit ."--. / pause
                > 36 sprite(4).ink=36 & member("you ENTER").text="you hit ENTER" --
                enter
                > 88 member("you 6").text="you hit 6"--6 /jump ahead
                > 86 member("you 4").text="you hit 4"--4 /jump back
                > end case
                > end
                You can't do two commands on the same line. Move the other to the next
                line, like so:
                on keyDown
                82: member("you 0").text="you hit 0" --0 /play
                65: member("you .").text="you hit ."--. / pause
                36: sprite(4).ink=36
                88: member("you 6").text="you hit 6"--6 /jump ahead
                86: member("you 4").text="you hit 4"--4 /jump back
                end case
                end
                The & operator is the string concatinator, so I'm surprised this didn't
                simply error out instead. But the above code should work. I think. (Not
                sure if the browser will capture the Enter key before the Shockwave does. A
                lot of keys have that problem in Shockwave.)
