6 Replies Latest reply on Mar 19, 2007 10:20 PM by kglad
    My input AS is right but Flash says it's wrong
    twistedpancreas Level 1
      I've done a simple check input coding which should check for the inputed number of 0.09952. Problem is Flash says that the correctly inputed number is incorrect. Can anyone help???
      Check out my Flash8 file here:
      http://home.exetel.com.au/twistedpancreas/images/calculation.fla
      Everything seems to be in order. The only thing i have changed is that my correct number used to be 0.09954, but i changed it to 0.09952. Now only the number 0.09954 will work if var KHPanswer:Number = 0.09954;
      Any help would be much appreciated.
      Thanks in advance.
      PB
