If anyone could provide some insight into using application
variables declared in application.cfm, but retrieved in asp code,
it would be appreciated.
GOAL: Retrieve values into an asp page from application
variables in application.cfm.
PROCESS: Defined the variables in application.cfm. On an asp
page, defined the application variable in Window -> Bindings.
The application variables defined in the source code show up.
Attempt to retrieve the application variable in the asp page by
using the command: var_destination = Application("var_name")
It seems like whatever I try, the variable is empty. After
looking around on the web, I also saw that the equivalent to
application.cfm in asp is global.asa. I also tried setting up this
file, along with the variables, did the binding, and used the same
commands, and also was not able to retrieve any application
variables.
What am I missing?
