0 Replies Latest reply on Nov 25, 2014 8:26 PM by spencer_reza
    CS5: Green Pixelated Video in Source Monitor playback for clips w/ 44100 hz - Compressed - Stereo
    spencer_reza
      I am having issues with 2 of the 14 clips I have imported into a new project.  I am using Adobe Premiere Pro CS5. -- I have enclosed the properties of a few clips + a screen shotScreen Shot 2014-11-25 at 8.22.36 PM.png
      The two clips giving me issue differ from the other clips the following way:
      44100 hz - compressed - stereo
      the other 12 clips were encoded with the following and they play back properly in the source monitor/sequence
      44100 hz - 16-bit -stereo
      Here are the full properties of the bad clip(s)
      OBvid11.mov
      Type: MPEG Movie
      File Size: 513.3 MB
      Image Size: 1920 x 1080
      Pixel Depth: 32
      Frame Rate: 24.00
      Source Audio Format: 44100 Hz - compressed - Stereo
      Project Audio Format: 44100 Hz - 32 bit floating point - Stereo
      Total Duration: 00:04:44:18
      Average Data Rate: 1.8 MB / second
      Pixel Aspect Ratio: 1.0
      Here are the properties of a good clip - you see it shows way more information
      OBvid10.mov
      Type: QuickTime Movie
      File Size: 5.2 MB
      Pixel Depth: 24
      Frame Rate: 24.00
      Source Audio Format: 44100 Hz - 16 bit - Stereo
      Total Duration: 00:00:02:17
      Average Data Rate: 1.9 MB / second
      QuickTime Details:
      Movie contains 1 video track(s), 1 audio track(s) and 0 timecode track(s).
      Video:
      There are 64 frames with a duration of 1837/44100ths.
      Video track 1:
      Duration is
      Average frame rate is 0.01 fps
      Video track 1 contains 1 type(s) of video data:
      Video data block #1:
      Frame Size = 1920 x 1080
      Compressor = H.264
      Quality = Normal (3.00)
      Temporal = Normal (3.00)
      Audio:
      Audio track 1 contains 1 type(s) of audio data:
      Audio data block #1:
      Format = 16 bit - Stereo
      Rate = 44100 Hz
      Compressor =  16-bit Little Endian
      I dont actually need the audio from any of the clips.  Is there a way that I can fix this?
      Thanks so much for taking the time to read this.
