2 Replies Latest reply on Mar 20, 2015 1:31 AM by Elementathens
    Premiere constantly freezes video while playback
    Thanos_Kamaretsos Level 1
      For a bout 2 months now of using Premiere pro cc 2014, i am very disappointed of a constant behaviour. trying to play timelines of low complexity (3mins long, sometimes no effects, and only one video track and a title or a matte ), keeps freezing in random spots of the timeline while the audio continues to play. There are times that it even crashes completely after this.
      The materials used are mxfs or quicktimes ( H264) from common DSLR cameras
      It happens even if the timeline is rendered or not
      The only solution found so far is immediately quit and reopen Premiere, but even after this it can happen again. It is very emberassing as it happens while i play the edit in front of clients.Pl
      Hardware Overview:
        Model Name: Mac Pro
        Model Identifier: MacPro5,1
        Processor Name: Quad-Core Intel Xeon
        Processor Speed: 2.4 GHz
        Number of Processors: 2
        Total Number of Cores: 8
        L2 Cache (per Core): 256 KB
        L3 Cache (per Processor): 12 MB
        Memory: 24 GB
        Processor Interconnect Speed: 5.86 GT/s
        Boot ROM Version: MP51.007F.B03
        SMC Version (system): 1.39f11
        SMC Version (processor tray): 1.39f11
      NVIDIA Quadro K5000:
        Chipset Model: NVIDIA Quadro K5000
      STORAGE
        Available: 3.34 TB (3,340,379,062,272 bytes)
        Capacity: 4 TB (4,000,109,887,488 bytes)
        Mount Point: /Volumes/EDIT_05
        File System: Journaled HFS+
        Writable: Yes
        Ignore Ownership: No
        BSD Name: disk3
        Volume UUID: 5595E7DD-4A27-39E6-AE37-0C4219CE14E8
        Physical Drive:
        Media Name: EDIT_05
        Medium Type: Rotational
        Protocol: SATA
        Internal: Yes
        Partition Map Type: Unknown
        S.M.A.R.T. Status: Not Supported
      PREMIERE PRO LATEST VERSION (8.1)
      FOOTAGE (H264 OR MXF OR QUICKTIME) FULL HD(1920X1080)
      USING MERCURY (GPU)
      NO THIRD PARTY HARDWARE OUPUT
        • 1. Re: Premiere constantly freezes video while playback
          geophrian Level 1
          Having the same problem. Using MXF video files from the Sony F5. Was never a problem until the past few months and seems to be getting worse as time goes on. I've tried Premiere Pro CC (2014), and using the previous Premiere Pro CC (hoping it may work like it used to) and no luck.
          Any ideas, solutions, help at all would be greatly appreciated. It's to the point where some projects I can't even watch all the way through. I just have to guess that it is right and hope the video exports so I can view it that way. I have to save after ever step, before renders and pretty much any time I click the mouse. It's making Premiere absolutely useless. Edits that should take a few hours take days now.
          After Effects has no troubles at all using the exact same footage and seems to be operating flawlessly. .
          • 2. Re: Premiere constantly freezes video while playback
            Elementathens Level 1
            It is a pity that no one from adobe is answering this post. Anyway, having made testings found the following
            1) It happens on the mac ( not the PC )
            2) I found the following sequence settings to degrade the problem to 20% ( I mean the codec - Apple pro res 422
            3) To eliminate the problem I import the files and while logging, and starting a first cut, i convert them in backround ( using Mpeg Streamclip - personal choice ) at Apple pro res 422 (any flavor) and when this is done i simply reconnect them to the Pro res ( using the above settings ) and problem gone...
            But all the above is a roundtrip not a solution. If anyone from Adobe is out there...:)
